Home /Air Purifier Reviews /AirFanta 5Pro Review – The 3Pro…
AirFanta 5Pro Review – The 3Pro Grows (and Glows) Up
Outside of building your own Corsi-Rosenthal box, the AirFanta 3Pro has been just about the most cost-effective air purifier on the market since it was released. At $149 (it has since crept up to $164.99), it offered a rated CADR of 702 m³/h, roughly twice what most purifiers in this price range manage, and since I reviewed it back in December 2024, it has been my go-to recommendation for anyone who wants as much clean air per dollar as possible. What did you give up for that price? Quite a lot. There was no sensor, no auto mode, no app, and it looked exactly like what it was – a pre-built CR box with four fans on top. It was a purifier for people who only care about raw performance.
AirFanta 5Pro Air Purifier
The AirFanta 5Pro is its successor, and it improves on the 3Pro in two key ways. Firstly, it’s smarter, with an integrated PM2.5 sensor, a small screen and, finally, an auto mode. Secondly, it’s vastly more refined. The filters now sit in proper panels that snap together with magnets, the fans are recessed inside the frame, and the whole thing looks like a product rather than a DIY project. I’ll be comparing the two devices directly in a separate article, so in this review, I want to focus on the 5Pro on its own terms.
Since I’ve recently been expanding my purifier testing methodology and working through a whole range of air purifiers, I’ve been super excited to get this device into my test room. Well, spoiler alert, after having the 5Pro in our living room for about two weeks, I’ve never seen our PM levels remain so consistently low.
AirFanta sent me a sample of the 5Pro (the version without carbon filters) for this review. Below, I’ll start with performance and filtration, including how it fared in my test room against the other purifiers I’ve tested, before moving on to the design, the new sensor and auto mode, noise and power consumption, and finally, pricing. If you just want the verdict, feel free to skip ahead to the conclusion. Otherwise, read on!
I independently test air purifiers in the same sealed 29.4 m³ room at home. I fill it with incense smoke, switch the purifier on remotely and measure how quickly it clears the air, three runs at each speed, then record its noise from one metre and its power draw, so every result can be compared directly with the next.
Where a brand’s claims come from a lab test, I say which standard it used and how it differs from my own setup, and where I can’t measure something myself, such as filter certification, I lean on third-party results and name the source. You can read exactly how I score purifiers on my methodology page.
Performance & Filtration
AirFanta 5Pro Filters
Let’s start with the filters, as they are the part of this device that matter most. The 5Pro uses four identical filter panels, one for each side of the cube, and each holds a flat sheet of polypropylene filter media behind a plastic grille, with the white filter side facing outwards. AirFanta rates the media as EPA11 (you may also see it written as H11), which means a single-pass efficiency of 95% for 0.3 micron particles, and says the usable filter area is 25% larger than on the 3Pro.
If you’ve read my AirFanta 3Pro review, you’ll know that choosing H11 over the H13 filters many brands advertise is deliberate, and it’s a choice I agree with. An air purifier circulates a room’s air through its filter again and again, so the amount of air moved matters far more than whether each pass captures 95% or 99.97% of particles, and H13 media’s far higher pressure drop means less airflow, more noise, or both. I’d rather have 95% efficiency at 700 m³/h than 99.97% at half that.
The 5Pro is sold in two versions, and the only difference is the filters. The ‘Without Carbon’ version, which is the one I was sent, has the plain EPA11 panels, while the ‘With Carbon’ version adds 120 grams of activated carbon to each panel for VOCs and odours and costs $10 more. The panels are the same size, so you can switch between them at replacement time, but carbon adds resistance, so the AHAM results below only apply to the version without it.
AirFanta also provided two lab reports from the Guangzhou Institute of Microbiology, in which the 5Pro ran at maximum speed for 60 minutes in a 30 m³ chamber and removed over 99.99% of H1N1 influenza A virus in one test and over 99.99% of Staphylococcus albus bacteria in the other. While this is impressive, it’s worth pointing out that in 60 minutes at this airflow, the air in a room that size passes through the filters around 20 times over, and any purifier with a decent filter should remove practically everything under those conditions. It’s nice to have these reports, but don’t read into them too much.
Now, let’s get to the number that matters most – the CADR (clean air delivery rate). The 3Pro’s 702 m³/h came from independent testing by community members rather than a certified lab (at least at the time when I reviewed it). With the 5Pro, AirFanta has gone through the AHAM Verifide program, which I appreciate, as manufacturers can (and do) publish optimistic numbers, and certified testing is the easiest way to keep them honest. The certification report, dated October 2026 and based on two units, gives the following results:
AHAM Verifide result (5Pro, Without Carbon)Certified rating
Smoke CADR379 CFM (644 m³/h)
Dust CADR408 CFM (693 m³/h)
Pollen CADR450 CFM (765 m³/h)
PM2.5 CADR393 CFM (668 m³/h)
Recommended room size587 ft² (55 m²)
The two units came in at 380.1 and 378.2 CFM for smoke, which is about as consistent as you could hope for, while drawing 40.8W and 40.2W. You might have noticed that 644 m³/h is lower than the 3Pro’s 702 m³/h. However, the two figures come from different tests, and AHAM’s smoke test is a demanding one. As you’re about to see, my own testing suggests the 5Pro has been rated conservatively.
Speaking of my own testing, let’s get to it. My process is the same one I use for every air purifier I review. I burn incense in my 29.4 m³ test room until the PM2.5 concentration reaches roughly 500 µg/m³, wait for it to burn out, then trigger the purifier remotely (so nobody is in the room disturbing the air) and record how long the concentration takes to fall below 5 µg/m³. Readings come from three AirGradient ONEs (I-9PSL, factory calibrated), and each speed gets three runs. For the full details of my test room and methodology, please refer to my Levoit Vital 200S-P review.
The usual caveats apply. My test room is a real room with furniture, air gaps and surfaces for particles to settle on, not a sealed chamber, so my figures won’t line up exactly with lab results, and a difference between the two doesn’t mean the manufacturer is wrong. Incense also skews towards smaller particles than the smoke used in chamber testing, and the AirGradient ONE can’t see particles below about 0.3 microns. While this testing isn’t scientific, every device is tested under the same conditions in the same room.
I tested the 5Pro at maximum speed, 50% and 25%, the lowest setting the device allows. Since the 5Pro has a percentage dial rather than fixed speed levels, my half-speed test was exactly 50%, which is worth keeping in mind when comparing it to the devices below, where ‘half speed’ means whichever medium mode the device offers. Every one of the nine runs produced a clean decay curve (r² of 0.993 or higher), and the results were remarkably consistent.
How fast the 5Pro clears a room
How fast the 5Pro clears a room Decay in µg/m³ of 4 series (Max speed; Half speed (50%); Lowest speed (25%); Room alone) against time in minutes, measured in a 29.4 m³ room. 0 100 200 300 400 500 0 5 10 15 20 25 30 35 40 PM2.5 (µg/m³) Minutes elapsed
Shading spans the fastest and slowest run at each moment.
Key figures, mean of runs
Series Runs Measured CADR To 50% To 90% To 99%
Max speed 3 730 m³/h 1:56 5:28 9:38
Half speed (50%) 3 437 m³/h 3:10 9:11 16:00
Lowest speed (25%) 3 223 m³/h 6:25 18:03 31:20
Measured CADR is the median of 3 runs, fitted to the exponential part of each decay curve in a 29.4 m³ room. The manufacturer states 644 m³/h. A real room isn't a sealed test chamber, so my figures won't line up exactly with a lab result, and a difference here doesn't mean the manufacturer is wrong.
29.4 m³ · AirGradient ONE I-9PSL (factory calibrated) · Download max speed data (CSV) · Download half speed (50%) data (CSV) · Download lowest speed (25%) data (CSV) · Download room alone data (CSV)
At maximum speed, the 5Pro took my test room from 500 µg/m³ to below 5 µg/m³ in 9 minutes and 38 seconds, with half of the smoke gone in under two minutes and 90% gone in 5:28. Fitting the three decay curves gives a median measured CADR of 730 m³/h. To put that in perspective, it’s the highest CADR I’ve measured in my test room, and it isn’t even close! The next best is the Mijia Smart Air Purifier 6 at 453 m³/h. As a cross-check, calculating the CADR from the ONE’s 0.3 micron particle counts instead gave figures within about 6% at every setting.
Against the AHAM figures, my result is 13% above the smoke CADR of 644 m³/h. In other words, my testing backs up AirFanta’s claim, and if anything, the company has rated the device conservatively. I wouldn’t go as far as saying the 5Pro outperforms its rating, though, as my method differs from the lab test in ways that push the result upwards – the ONE doesn’t see the smallest particles, and my figure includes the room’s own natural clean-up of roughly 9 m³/h – so what I can say is that the certified number is a fair one, and that the device delivers it in a real room.
At 50%, the measured CADR dropped to 437 m³/h, with the room taking 16:00 to clear, and at 25%, it dropped to a ‘mere’ 223 m³/h and 31:20. Put another way, the half setting keeps 60% of the device’s maximum CADR and the lowest setting keeps 31%, so CADR falls roughly in line with the fan percentage. This matters because, as with every purifier I’ve tested, maximum speed is something you’ll reserve for quick cleans, and the lower settings are where the 5Pro will spend most of its life.
So, how does the 5Pro compare to the other purifiers I’ve tested at a similar price? Below, I’ve put it alongside the Mijia Smart Air Purifier 6, the Levoit Vital 200S-P and the Xiaomi Smart Air Purifier 4 Lite.
DeviceClaimed CADRMeasured max CADR (vs claim)Measured half-speed CADR (% of max)Below 5 µg/m³ at max / half
AirFanta 5Pro644 m³/h730 m³/h (+13%)437 m³/h (60%)9:38 / 16:00
Mijia 6443 m³/h453 m³/h (+2%)301 m³/h (66%)15:26 / 24:09
Levoit Vital 200S-P425 m³/h387 m³/h (-9%)172 m³/h (44%)19:31 / 42:48
Xiaomi 4 Lite360 m³/h350 m³/h (-3%)155 m³/h (44%)21:02 / 45:03
Max speed compared
Max speed compared Decay in µg/m³ of 5 series (AirFanta 5Pro, max speed; Mijia 6, max speed; Levoit Vital 200S-P, max speed; Xiaomi 4 Lite, max speed; No purifier, room alone) against time in minutes, measured in a 29.4 m³ room. 0 100 200 300 400 500 0 5 10 15 20 25 30 PM2.5 (µg/m³) Minutes elapsed
AirFanta 5Pro, max speed 3 730 m³/h 1:56 5:28 9:38
Mijia 6, max speed 3 453 m³/h 2:45 8:30 15:26
Levoit Vital 200S-P, max speed 3 387 m³/h 3:29 10:02 19:31
Xiaomi 4 Lite, max speed 3 350 m³/h 3:56 11:36 21:02
Measured CADR is the median of 3 runs, fitted to the exponential part of each decay curve in a 29.4 m³ room. A real room isn't a sealed test chamber, so my figures won't line up exactly with a lab result, and a difference here doesn't mean the manufacturer is wrong.
29.4 m³ · AirGradient ONE I-9PSL (factory calibrated) · Download airfanta 5pro, max speed data (CSV) · Download mijia 6, max speed data (CSV) · Download levoit vital 200s-p, max speed data (CSV) · Download xiaomi 4 lite, max speed data (CSV) · Download no purifier, room alone data (CSV)
At maximum speed, the 5Pro cleans about 61% more air than the Mijia 6, 89% more than the Vital 200S-P, and roughly double the Xiaomi 4 Lite. However, the more interesting comparison is at the lower settings. At just 50%, the 5Pro nearly matches the Mijia 6 running flat out (437 vs 453 m³/h, and 16:00 vs 15:26 to clear my room), and it comfortably beats both the Vital and the 4 Lite at their maximum speeds. Even at 25%, it cleared my room in 31:20, faster than the Vital 200S-P and 4 Lite managed at half speed, and roughly the same as the cheaper Xiaomi 4 Compact running at maximum (216 m³/h and 32:01).
Half speed compared
Half speed compared Decay in µg/m³ of 5 series (AirFanta 5Pro, half speed (50%); Mijia 6, half speed; Levoit Vital 200S-P, half speed; Xiaomi 4 Lite, half speed; No purifier, room alone) against time in minutes, measured in a 29.4 m³ room. 0 100 200 300 400 500 0 10 20 30 40 50 60 PM2.5 (µg/m³) Minutes elapsed
AirFanta 5Pro, half speed (50%) 3 437 m³/h 3:10 9:11 16:00
Mijia 6, half speed 3 301 m³/h 4:36 13:24 24:09
Levoit Vital 200S-P, half speed 3 172 m³/h 7:25 22:28 42:48
Xiaomi 4 Lite, half speed 3 155 m³/h 8:17 23:54 45:03
29.4 m³ · AirGradient ONE I-9PSL (factory calibrated) · Download airfanta 5pro, half speed (50%) data (CSV) · Download mijia 6, half speed data (CSV) · Download levoit vital 200s-p, half speed data (CSV) · Download xiaomi 4 lite, half speed data (CSV) · Download no purifier, room alone data (CSV)
Overall, the results here are hard to fault. The 5Pro is the most powerful purifier I’ve measured by a wide margin, and, more importantly for everyday use, it can run at 25% and still outperform most of the competition running at half speed. AHAM’s recommended room size of 587 ft² (55 m²) is a good guide to the space it suits, and if you want to work out how much purifying power you actually need for your room, you can use the tool below.
Purchase AirFanta 5Pro from AirFanta
Purchase AirFanta 5Pro from Amazon
Out of the box, the 5Pro comes as six plates: a bottom cover, four identical filter panels, and a top cover that holds the four fans, the PM2.5 sensor and the screen. Assembly is a case of standing the panels on the bottom cover and dropping the top cover on. That sounds just like the 3Pro, but in practice, it’s a world apart. The 3Pro was finicky to hold together while fitting the fan assembly, and I sometimes needed a second pair of hands to keep the filters upright while I mounted the top. The 5Pro remedies this with magnets – 32 of them, embedded in the plastic – so the panels snap into place and stay there. The only thing to keep in mind is to line up the slot for the power plug, and the whole process takes about a minute. Disassembly is just as quick, as pressing the two buttons on the sides of the top cover releases it.
AirFanta 5Pro Magnets
The magnets are glued in, and the company had the device tested by a third-party lab against the US magnet safety standard for toys (16 CFR 1262), with the magnets staying put through soaking, repeated separation, dropping, impact and compression. It’s a small thing, but it’s the kind of detail that shows how much effort has gone into creating this device.
The power arrangement is also clever. The 5Pro uses a removable barrel cable from a compact 12V power brick, which is great in itself, as a damaged cable becomes a cheap fix rather than a dead purifier. More interesting is that the cable can’t be plugged in unless the top cover is pushed fully down onto the filters, and the top cover can’t be removed while the cable is plugged in. In other words, you can’t power the device when it isn’t assembled. Since the fans are easily touchable from the inside once the top is off, that’s a nice bit of foolproofing. The fans are also recessed inside the frame rather than sitting exposed on top as they did on the 3Pro, which makes them safer around children and animals – which matters to me more than it did a year ago, as we now have a child who will be walking in a few months.
AirFanta 5Pro Power Button
Everything you interact with is on top of the device. The speed dial has moved from the power brick (where it lived on the 3Pro) to the top cover. It’s bright orange, which I’m not necessarily a fan of, as it stands out against the rest of the device (likely the intention). However, it works well. It’s notched, so you can feel each 5% step from 25% to 100% as you turn it, pressing it turns the device on or off, and holding it for three seconds switches to auto mode. Beside it is a small screen showing two numbers – the fan speed as a percentage and the PM2.5 concentration in µg/m³.
I’m a fan of this too, as there’s no AQI here, just the raw reading. The screen is recessed below the surrounding plastic (AirFanta’s engineer, Adam Wong, has explained on X that this is so it’s less likely to be pressed or damaged when packed in a bag) and switches itself off after 30 seconds. On the opposite side of the top cover from the dial is the PM2.5 sensor, which looks to be of Plantower make. The device also remembers its last speed and mode when it’s unplugged, which is a welcome feature (and made my testing far easier!).
AirFanta 5Pro PM2.5 Sensor
Compared to the 3Pro, the 5Pro also simply looks far better. All four sides now have a plastic grating in front of the filter, and the filters sit in proper panels rather than being exposed, so the device looks finished. Don’t get me wrong, this is still a very simple air purifier. There’s no app, no remote, no timer and no filter indicator, but it’s a significant design upgrade.
A couple of further changes are less visible, and I only learned about them from Adam Wong’s posts. On the 3Pro, a bump in shipping could deform a fan bearing, after which the fan would start making noise, and because all four fans were soldered together, one failed fan meant replacing the whole assembly. On the 5Pro, each fan is screwed to the top cover, so one can be replaced on its own (AirFanta says a pair will cost $15-20 shipped), and the bearing housing is now a machined copper tube rather than plastic, which should make the fans far more resistant to knocks. These aren’t headline features, but they again highlight the attention to detail that has gone into creating this device.
AirFanta 5Pro Fans
As with the 3Pro, the 5Pro moves its air with four 140mm PC-style case fans, pulling air in through all four filter panels and pushing it out of the top. Based on my performance results, this seems to have been the right call, as four large, slow-spinning fans pulling air through a massive combined filter area move a lot of air for very little power. It’s also why the 5Pro performs far better than average at low speeds, where the fans barely need to work to pull air through so much media. The approach comes with one caveat, though. Since the device draws air in through all four sides, it needs a gap around it to perform at its best, and AirFanta recommends 38cm (15 inches) of clearance on each side. Pushed into a corner, it will still work, but you’ll be blocking one or two of the four filters and losing some performance.
Finally, size. Assembled, the 5Pro measures 33 x 33 x 39cm and weighs 4.1kg (9 lbs) for the non-carbon version or 4.9kg with carbon filters, which makes it 1cm wider and 7cm taller than the 3Pro. It’s a reasonably large device, but not a heavy one, and because it disassembles in seconds, it packs down into a stack of six plates, and I can confirm it fits in my carry-on suitcase (albeit taking up a lot of room). Even if you never take it anywhere, moving it between rooms or storing it when the air is clean is far less of a chore than with a conventional purifier.
Noise & Power Consumption
AirFanta 5Pro Speed Dial
Now, let’s talk about the two things that decide which speed you’ll be leaving the purifier on – how loud it is, and what it costs to run. As with every purifier I test, I measured the sound level one metre from the device at each of the three settings I tested for performance.
Fan speedNoise (1 m)PowerMeasured CADR
100%63 dBA40W730 m³/h
50%50 dBA10W437 m³/h
25%43 dBA2W223 m³/h
At maximum speed, I measured 63 dBA. That puts the 5Pro level with the Provirtec Pawtent Pro as the loudest purifier I’ve measured at full power, a few dBA above the Mijia 6 (59 dBA), the Levoit Vital 200S-P (60 dBA) and the Xiaomi 4 Lite (58 dBA), although you’re also getting 61% to 109% more clean air for that noise. At 50%, the reading dropped to 50 dBA, and at 25%, to 43 dBA, which is only 5-6 dBA above my room’s own noise floor of 37-38 dBA.
Measured noise
0 14 28 42 56 70 Max Medium dBA AirFanta 5Pro · Max · 63 dBA 63 Mijia 6 · Max · 59 dBA 59 Xiaomi 4 Lite · Max · 58 dBA 58 Levoit Vital 200S-P · Max · 60 dBA 60 AirFanta 5Pro · Medium · 50 dBA 50 Mijia 6 · Medium · 46 dBA 46 Xiaomi 4 Lite · Medium · 44 dBA 44 Levoit Vital 200S-P · Medium · 43 dBA 43
Lowest settings are left out so every device is compared at the same two speeds. The 5Pro measured 43 dBA at 25%, while the others read within a couple of dBA of the room's own noise floor at their lowest settings.
Here’s where the four-filter design pays off, though, as the number that matters isn’t how loud the 5Pro is at maximum, as you’ll rarely use it there, but how loud it is while delivering a given amount of clean air. At 50%, the 5Pro produces 437 m³/h at 50 dBA. The Mijia 6 needs to run flat out to produce a similar 453 m³/h, and at that speed, I measured it at 59 dBA. That’s 9 dBA less noise from the 5Pro for the same clean air, which on the logarithmic decibel scale is close to half the perceived loudness.
DevicePower (max / half / lowest)Measured CADR (max / half)m³/h per W at maxm³/h per W at half
AirFanta 5Pro40 / 10 / 2W730 / 437 m³/h18.343.7
Mijia 633 / 9 / 3W (sleep)453 / 301 m³/h13.733.4
Xiaomi 4 Lite32 / 9 / 3W (night)350 / 155 m³/h10.917.2
Levoit Vital 200S-P42 / 8 / 4W (sleep)387 / 172 m³/h9.221.5
Power consumption tells a similar story. I measured 40W at maximum, 10W at 50% and just 2W at 25%, which lines up almost exactly with AHAM’s figures (40.8W and 40.2W at maximum) and with AirFanta’s own table (40W, 8W and 1.5W). Those numbers are low in absolute terms, but they’re remarkable once you set them against the airflow. At maximum, the 5Pro delivers around 18 m³/h of clean air per watt, and at 50%, that rises to roughly 44 m³/h per watt. The Mijia 6, which was the most efficient purifier I’d measured until now, manages 13.7 and 33.4. Below, I’ve put the four devices side by side:
Clean air per watt
0 4 8 12 16 20 AirFanta 5Pro Mijia 6 Xiaomi 4 Lite Levoit Vital 200S-P m³/h per watt AirFanta 5Pro · 18.3 m³/h per watt 18.3 Mijia 6 · 13.7 m³/h per watt 13.7 Xiaomi 4 Lite · 10.9 m³/h per watt 10.9 Levoit Vital 200S-P · 9.2 m³/h per watt 9.2
Four large fans pulling air through four large filters is simply a far more efficient way to move air than one small fan pushing it through one small filter, and at half speed, the 5Pro produces 30% more clean air per watt than the next best device I’ve measured.
What does this mean for your electricity bill? Using my usual assumptions (half speed, twelve hours a day, at $0.29/kWh), the 5Pro costs around $13 per year to run, about the same as the far smaller Xiaomi 4 Compact at its own half speed. Even if you ran it at maximum 24 hours a day, which nobody will, you’d be looking at around $100 per year. Electricity, in short, is not a cost you need to worry about with this device.
Everyday Use
AirFanta 5Pro PM2.5 Measurement
For most of the past two weeks, the 5Pro has lived in our living room, which is a combined living room and kitchen area, where it runs alongside the Mijia 6. After some experimenting, I’ve settled on 35% as the setting I leave it on. That’s roughly 300 m³/h of clean air, going by my 25% and 50% results, at a sound level I can’t separate from the room, and I’ve found it to be the best balance for our space. Between the two devices, both running at low settings, the whole space stays clean around the clock, and, as I mentioned in the introduction, I’ve never seen our PM levels remain so consistently low.
The big new feature in everyday use is the PM2.5 sensor and the auto mode that comes with it. Alongside the raw reading, the screen’s border changes colour through six bands – green up to 15 µg/m³, yellow to 40, orange to 65, red to 150, purple above that, and a sixth ‘hazardous’ band above 250. In auto mode, the fan follows the same bands, running at 25% below 15 µg/m³, 50% up to 40, 65% up to 65, 80% up to 150, and 100% above that.
AirFanta 5Pro Screen
In practice, auto mode is not bad, but it’s not great either. The logic is simple and predictable, which I appreciate, and it does ramp up when something happens in the room. However, the thresholds are lenient. Personally, I aim for less than 5 µg/m³ at all times, and this device considers anything up to 15 µg/m³ good enough to idle at the lowest setting. As with nearly every auto mode I’ve tested, it’s too lenient for me to rely on, so I leave the 5Pro in manual mode and pick the speed myself.
AirFanta 5Pro PM Sensor
As for the sensor itself, since the 5Pro has no connectivity, I could only compare its readings visually. However, it generally read within 5%-10% of my dedicated air quality monitors, which is a good sign.
There is no app, no Wi-Fi and no remote, which will rule the 5Pro out for some people. However, because the device remembers its last speed and mode when it loses power, you can run some very simple automations with a smart socket – a schedule that turns it on while you cook dinner or off overnight, or a rule that triggers it from a separate air quality monitor. It’s not a substitute for proper connectivity, but for a purifier this simple, it offers some simple automations.
The 5Pro is priced at $189.99 for the version without carbon and $199.99 with carbon filters. Here in the Philippines, it sells for ₱12,400, a touch above the Mijia 6 at around ₱10,500 but well below the Levoit Vital 200S-P at around ₱20,000. However since most of my readers are in the US, I’ll keep the focus on US pricing from here. Importantly, the 5Pro isn’t that much more expensive than the 3Pro, which is now $164.99 with the standard filters.
Against the other purifiers I’ve tested in this price range, the value on offer is hard to argue with. The Mijia 6 lists at around $231 in the US, the Levoit Vital 200S-P at $189 and the Xiaomi 4 Lite at $199, and none of them comes close on clean air per dollar:
What you pay per m³/h of clean air
0 0.13 0.26 0.39 0.52 0.65 AirFanta 5Pro Mijia 6 Levoit Vital 200S-P Xiaomi 4 Lite USD per m³/h AirFanta 5Pro · 0.26 USD per m³/h 0.26 Mijia 6 · 0.51 USD per m³/h 0.51 Levoit Vital 200S-P · 0.49 USD per m³/h 0.49 Xiaomi 4 Lite · 0.57 USD per m³/h 0.57
To get the 5Pro’s level of performance from a brand like Levoit or Coway, you’re generally looking at a far larger device in the $300-500 range or above. For $190, the 5Pro is one of the very few purifiers that can capably change the air in a living room, a large bedroom or even a small apartment.
Replacement filters for the 5Pro cost $59 for a set of four without carbon, or $75 with carbon, and AirFanta recommends replacing them every 12 months. That’s not cheap for a single purchase. However, you’re buying four filters at once, and the 12-month interval is twice as long as the 6 months recommended for the Mijia 6, the Vital 200S-P and the 4 Lite. Over a year, that works out at $59 for the 5Pro against around $74 for the Mijia 6 (two filters at $37), $80 for the Vital 200S-P and $35-50 for the 4 Lite.
In other words, the filters are relatively reasonable once you account for how long they last. Add around $13 of electricity at half speed, and the 5Pro costs roughly $72 per year to run, which is less than either the Mijia 6 or the Vital 200S-P.
What each costs to run for a year
0 20 40 60 80 100 Electricity Filters Total USD/year AirFanta 5Pro · Electricity · 12.7 USD/year 12.7 Mijia 6 · Electricity · 11.43 USD/year 11.43 Levoit Vital 200S-P · Electricity · 10.16 USD/year 10.16 Xiaomi 4 Lite · Electricity · 11.43 USD/year 11.43 AirFanta 5Pro · Filters · 59 USD/year 59 Mijia 6 · Filters · 74 USD/year 74 Levoit Vital 200S-P · Filters · 80 USD/year 80 Xiaomi 4 Lite · Filters · 50 USD/year 50 AirFanta 5Pro · Total · 71.7 USD/year 71.7 Mijia 6 · Total · 85.43 USD/year 85.43 Levoit Vital 200S-P · Total · 90.16 USD/year 90.16 Xiaomi 4 Lite · Total · 61.43 USD/year 61.43
Electricity assumes half speed, twelve hours a day, at $0.29/kWh. Filters use the most conservative manufacturer interval. Prices are official retail in a Western market: US where the device is sold there, Europe where it is not. Other regions differ, sometimes sharply.
That leaves the most obvious competitor of all, the 3Pro. If raw performance per dollar is your only concern, the 3Pro is still a great offering, and you’ll save $25, as nothing about the 5Pro’s upgrades changes how much air the 3Pro moves. What the extra $25 buys you is everything else – the sensor and auto mode, the screen, the magnets, the enclosed and replaceable fans, the far better looks and the AHAM certification. I’ll dig into that choice properly in the comparison article, but in short, I think the 5Pro is a worthy successor, and for most people, I’d pay the difference.
After two weeks with the 5Pro, I think this is an amazing device if you want to clean even a large room, and it’s one of the few purifiers in this price range that can capably change the air in a living room, a large bedroom or a small apartment. At $189.99, it delivers a measured 730 m³/h of clean air, which is the highest CADR I’ve recorded from any purifier, and it does it from 40W.
However, the headline CADR isn’t actually the 5Pro’s biggest advantage. You’re not supposed to run a purifier at maximum speed all day, and this is one of the very few devices where even a quarter of its speed is capable of keeping the air in a small room clean. At half speed, you have over 400 m³/h of CADR at 50 dBA and 10W, which is crazy for a device this size. The four-filter design means the 5Pro barely has to try at the settings you’ll actually use, and that, more than the maximum, is what makes it so effective in a real home.
Of course, there is no smart connectivity, and auto mode is too lenient for my liking. If you want app control or a purifier that disappears into a modern interior, the Mijia 6 is a better fit, and if your room is small, you don’t need this much power. Filter replacements aren’t cheap at $59 a set either, although buying four at a time, once a year, makes them reasonable in practice.
It’s also clear from Adam Wong’s activity on X that he’s invested in making this device as good as it can be, and it shows in the details – the magnets, the replaceable fans, the recessed screen, the power interlock, and the decision to put the 5Pro through AHAM testing. This is the CR box for people who don’t want to make their own, or who, like me when I reviewed the 3Pro, find decent filters hard to source locally.
So, who should buy it? If you want the most clean air you can get for under $200, and you’re happy to turn a knob rather than open an app, the 5Pro is the purifier I’d recommend for a living room, an open-plan space, a large bedroom or a small apartment. If raw performance is all you care about and $25 matters, the 3Pro still does the main job. And if you need connectivity or a quieter maximum, look at the Mijia 6 instead – unless you need more air than it can move, in which case you’re back to the 5Pro.
  • Measured 730 m³/h at maximum, the highest CADR I’ve recorded and 13% above its AHAM smoke rating.
  • At 50% it still delivers 437 m³/h at 50 dBA and 10W, close to what the Mijia 6 manages flat out.
  • AHAM Verifide certification means the CADR figures were measured independently rather than in-house.
  • The onboard PM2.5 sensor generally read within 5% of my dedicated air quality monitors.
  • Remarkably efficient (2-40W), costing around $13 a year in electricity at half speed.
  • Magnetic panels assemble in about a minute and pack down small enough for a carry-on.
  • Thoughtful details: recessed, individually replaceable fans, a power interlock, a detachable cable and power-off memory.
  • Filters last 12 months, so it costs less to run each year than the Mijia 6 or the Vital 200S-P.
  • At 63 dBA on maximum, it’s level with the Pawtent Pro as the loudest purifier I’ve measured.
  • No app, Wi-Fi, remote, timer or filter indicator.
  • Auto mode idles at 25% all the way up to 15 µg/m³, which is too lenient for me.
  • Needs around 38cm of clearance on every side to perform at its best.
  • $59 for a set of filters is a sizeable one-off cost.
AirFanta 5Pro FAQ
What is the CADR of the AirFanta 5Pro?
AirFanta’s AHAM Verified smoke CADR is 379 CFM (644 m³/h), with 408 CFM for dust and 450 CFM for pollen. In my own testing, I measured 730 m³/h at maximum speed, 437 m³/h at 50% and 223 m³/h at 25%.
How big a room can the 5Pro clean?
AHAM rates it for rooms up to 587 ft² (55 m²) at 4.8 air changes per hour. In my 29.4 m³ test room, it took the PM2.5 concentration from 500 µg/m³ to below 5 µg/m³ in under 10 minutes at maximum speed.
Does the AirFanta 5Pro use HEPA filters?
The 5Pro uses four EPA11 (H11) filter panels rated at 95% efficiency for 0.3 micron particles. AirFanta chose these over H13 filters to keep airflow high, and in my testing, the trade-off pays off. A version with activated carbon is available for $10 more, and the two filter types are interchangeable.
Is the AirFanta 5Pro loud?
At maximum speed, I measured 63 dBA from one metre, which is louder than most purifiers I’ve tested. However, at 50% it drops to 50 dBA while still cleaning more air than most purifiers do at maximum, and at 25% it measured 43 dBA, only 5-6 dBA above my room’s background noise.
Does the 5Pro have an app?
No. The 5Pro has a PM2.5 sensor, a screen and an auto mode, but no app, Wi-Fi or remote. It does remember its last setting when unplugged, so it can be controlled with a smart socket.
Is the AirFanta 5Pro safe around children?
The fans are recessed inside the frame, the device can’t be powered unless it’s fully assembled, and the 32 magnets that hold it together have been tested to the US magnet safety standard for toys. As with any purifier, it shouldn’t be treated as a toy, but it’s a far safer design than the 3Pro.
How much do replacement filters cost?
A set of four replacement filters costs $59 without carbon or $75 with carbon, and AirFanta recommends replacing them every 12 months.
