Home /Air Purifier Reviews /Levoit Core 300 vs Vital 200S-P…
Levoit Core 300 vs Vital 200S-P – Which Levoit Purifier Should You Buy?
The Levoit Core 300 is one of the most popular compact air purifiers on the market, and for many people, the Vital 200S-P is the obvious next step up. That makes the Levoit Core 300 vs Vital 200S-P decision an important one, so I tested both devices over the same month, in the same room and with the same equipment, which makes them very easy to compare directly. When the Core 300 wasn’t being tested, it sat in my office either in place of or alongside the Xiaomi 4 Compact, and the Vital 200S-P has lived in our master bedroom ever since I finished testing it.
Before going further, a quick note on the naming. Levoit confirmed to me directly that the ‘-P’ suffix is a retail designation rather than different hardware, so the Vital 200S-P is the same machine as the Vital 200S. Everything points to the same being true of the Core 300 and the Core 300-P, so whichever name is on the box, everything below applies.
If you want the full detail on either device, you can find my Levoit Core 300 review and my Levoit Vital 200S-P review here. In this article, I will compare the two on performance, noise, smart features, design and cost before giving my recommendation on which one to buy.
The biggest difference between these two devices is how much air they can clean, so that’s where I want to start. Levoit rates the Core 300 at a CADR (clean air delivery rate – how much clean air the purifier produces each hour) of 240 m³/h, and the Vital 200S-P at 425 m³/h. Both figures are backed by AHAM Verifide, an independent body that tests purifiers in a sealed chamber, which is more than I can say for most of the purifiers I’ve tested.
To see how they perform in a real room, I tested both in my 29.4 m³ spare bedroom. I burned incense until PM2.5 reached around 500 µg/m³, waited for it to burn out, remotely triggered the purifier, and timed how long the concentration took to fall below 5 µg/m³. Each speed was run three times, and every reading came from the same AirGradient ONE I-9PSL sitting in the room.
Core 300 vs Vital 200S-P at max speed
Core 300 vs Vital 200S-P at max speed Decay in µg/m³ of 3 series (Levoit Core 300, max speed; Levoit Vital 200S-P, max speed; No purifier, room alone) against time in minutes, measured in a 29.4 m³ room. 0 100 200 300 400 500 0 5 10 15 20 25 30 35 40 PM2.5 (µg/m³) Minutes elapsed
Shading spans the fastest and slowest run at each moment.
Key figures, mean of runs
Series Runs Measured CADR To 50% To 90% To 99%
Levoit Core 300, max speed 3 258 m³/h 4:52 14:54 26:42
Levoit Vital 200S-P, max speed 3 387 m³/h 3:29 10:02 19:31
Measured CADR is the median of 3 runs, fitted to the exponential part of each decay curve in a 29.4 m³ room. A real room isn't a sealed test chamber, so my figures won't line up exactly with a lab result, and a difference here doesn't mean the manufacturer is wrong.
29.4 m³ · AirGradient ONE I-9PSL (factory calibrated) · Download levoit core 300, max speed data (CSV) · Download levoit vital 200s-p, max speed data (CSV) · Download no purifier, room alone data (CSV)
At max speed, the Vital 200S-P cleared the room in 19:31, while the Core 300 needed 26:42. That works out to 387 m³/h of measured clean air delivery for the Vital against 258 m³/h for the Core 300, so the Vital moves around 50% more air. Interestingly, the two devices land on opposite sides of their claims. The Core 300 beat its rating by about 7.5%, while the Vital came in around 9% under. Differences of this size are expected when testing in a real room filled with furniture and air gaps rather than a sealed chamber, so neither result means Levoit’s claims are false.
Claimed vs measured CADR
0 100 200 300 400 500 Claimed Max Medium Sleep m³/h Levoit Core 300 · Claimed · 240 m³/h 240 Levoit Vital 200S-P · Claimed · 425 m³/h 425 Levoit Core 300 · Max · 258 m³/h 258 Levoit Vital 200S-P · Max · 387 m³/h 387 Levoit Core 300 · Medium · 142 m³/h 142 Levoit Vital 200S-P · Medium · 172 m³/h 172 Levoit Vital 200S-P · Sleep · 83 m³/h 83
At half speed (level 2 on both devices), the gap narrows. The Vital measured 172 m³/h and cleared the room in 42:48, against 142 m³/h and 49:41 for the Core 300. That’s still around 21% more clean air from the Vital, and as you’ll see in the noise and running cost sections, it gets there with a lot less effort.
Core 300 vs Vital 200S-P at half speed
Core 300 vs Vital 200S-P at half speed Decay in µg/m³ of 3 series (Levoit Core 300, half speed; Levoit Vital 200S-P, half speed; No purifier, room alone) against time in minutes, measured in a 29.4 m³ room. 0 100 200 300 400 500 0 10 20 30 40 50 60 PM2.5 (µg/m³) Minutes elapsed
Levoit Core 300, half speed 3 142 m³/h 9:03 27:20 49:41
Levoit Vital 200S-P, half speed 3 172 m³/h 7:25 22:28 42:48
29.4 m³ · AirGradient ONE I-9PSL (factory calibrated) · Download levoit core 300, half speed data (CSV) · Download levoit vital 200s-p, half speed data (CSV) · Download no purifier, room alone data (CSV)
In terms of room size, AHAM recommends the Core 300 for rooms up to 222 ft² (about 21 m²), while Levoit rates the Vital 200S-P for 36 m² at 4.8 air changes per hour. Both use purely mechanical, three-stage filtration with no ioniser or UV lamp. However, the Vital’s filter is the better thought out of the two, with a washable nylon pre-filter and 250g of pelleted activated carbon, where the Core 300’s pre-filter can’t be removed for cleaning.
Purchase the Levoit Core 300 (Amazon)
Purchase the Levoit Vital 200S-P (Amazon)
Noise
Measured noise
0 13 26 39 52 65 Max Medium dBA Levoit Core 300 · Max · 59 dBA 59 Levoit Vital 200S-P · Max · 60 dBA 60 Levoit Core 300 · Medium · 47 dBA 47 Levoit Vital 200S-P · Medium · 43 dBA 43
Measured at one metre. Sleep is left out: both units read within a couple of dBA of the room's own noise floor at their lowest setting, which measures the room rather than the purifier.
Since either of these devices will likely spend its time in a room you sleep or work in, noise matters almost as much as speed. I measured both from one metre away, and at max speed there’s very little between them, with the Core 300 at 59 dBA and the Vital at 60 dBA. At full speed, every purifier in this class is loud.
Half speed is where the difference shows, and it’s the speed a purifier actually spends most of its time at. Here, the Vital 200S-P measured 43 dBA against the Core 300’s 47 dBA. Because the decibel scale is logarithmic, 4 dBA is a more meaningful gap than it sounds. I’ve had the Vital running at speed 2 near the foot of our bed for many nights without it bothering me, while 47 dBA from the Core 300 is still clearly audible, so in a bedroom you’ll probably want to run it on level 1 or sleep mode instead.
Sensors & Smart Features
The Core 300 and Vital 200S-P take completely different approaches to smart features. The Core 300 has no app, no auto mode and no sensor of any kind. Everything happens through the touch panel on top, which lets you choose between three fan speeds and sleep mode, set a 2-8 hour timer, turn off the backlight and lock the panel. If you want the app and auto mode in the same body, Levoit sells the Core 300S, officially priced at $149.99.
The Vital 200S-P is the opposite. It connects over WiFi to the VeSync app, which is one of the better manufacturer apps I’ve used. The scheduling goes further than most, and mine runs a burst at a higher speed for the first 30 minutes after sleep mode starts, drops to level 1 for an hour, and then holds sleep mode until morning. It also works with Alexa (including individual fan speeds by voice), Google Home and Home Assistant, although the Home Assistant integration polls VeSync’s cloud, so it won’t work without an internet connection.
The weak point is the Vital’s infrared PM sensor. Compared against my dedicated air quality monitors, it reads very high and regularly reports spikes that never happened, so I wouldn’t use auto mode on this device at all. Instead, pick a fixed speed or automate the purifier from a dedicated monitor, which is how I run mine. In other words, you’re paying for the app and the scheduling with the Vital, not for the sensor.
Design & Size
The two devices are shaped very differently, and this affects where you can put them. The Core 300 is a cylinder measuring 22 x 22 x 36 cm and weighing 3.39kg. It pulls air in from all sides, so it works best with some space around it. The Vital 200S-P is a chunky rectangle measuring 50.2 x 39.6 x 21.7 cm and weighing about 6kg, and it only pulls air in from the front. That means you can push it against a wall without losing airflow, which is exactly why it ended up in our bedroom.
The Vital also has a few small design touches that the Core 300 lacks. The U-shaped vent on the front keeps pet hair from plastering the mesh, the top of that vent doubles as a handle on each side, and a light sensor dims the control panel when the room goes dark. Its power cable is also detachable, while the Core 300’s is hardwired, meaning a damaged cable will mean replacing the whole unit. With six cats in the house, the Vital’s washable pre-filter and pet hair vent have earned their keep, although our cats have also managed to lock, unlock and switch off the Vital by sleeping on its control panel.
Filter changes are easy on both. On the Core 300, you rotate a plate on the bottom of the device to reach the filter, and a foam seal on top of the filter stops air from bypassing it. On the Vital, the front panel comes off with a gentle pull, and the filter change takes under a minute.
Pricing & Running Costs
Price per m³/h of measured CADR
0 0.11 0.22 0.33 0.44 0.55 Levoit Core 300 Levoit Vital 200S-P USD per m³/h Levoit Core 300 · 0.39 USD per m³/h 0.39 Levoit Vital 200S-P · 0.49 USD per m³/h 0.49
The Core 300 lists at $99.99 and is regularly discounted into the $80-90 range, while the Vital 200S-P lists at $189 and often sells for around $169.99. Looking at price against measured CADR at list price, the Core 300 is the better deal, at around $0.39 per m³/h of clean air against $0.49 for the Vital.
Running costs are where the comparison gets interesting. At half speed, the Core 300 draws 24 W, three times the Vital’s 8 W, despite moving less air. For every watt, the Vital delivers around three and a half times as much clean air at that speed (172 m³/h from 8 W, against 142 m³/h from 24 W). Running twelve hours a day at $0.29/kWh, that’s about $30 a year in electricity for the Core 300 and $10 for the Vital.
Power draw by fan speed
0 10 20 30 40 50 Max Medium Sleep Watts Levoit Core 300 · Max · 35 Watts 35 Levoit Vital 200S-P · Max · 42 Watts 42 Levoit Core 300 · Medium · 24 Watts 24 Levoit Vital 200S-P · Medium · 8 Watts 8 Levoit Core 300 · Sleep · 2 Watts 2 Levoit Vital 200S-P · Sleep · 4 Watts 4
Filters swing it back the other way. Both are rated for 6-12 months, and I plan around six, which works out to $60 a year for the Core 300’s $30 filters and $80 a year for the Vital’s $40 filters. Add everything together, and the two devices cost almost exactly the same to run, at $90.48 a year for the Core 300 and $90.16 for the Vital. The Core 300 spends its money on electricity, while the Vital spends it on filters.
What each costs to run for a year
0 20 40 60 80 100 Electricity Filters Total USD/year Levoit Core 300 · Electricity · 30.48 USD/year 30.48 Levoit Vital 200S-P · Electricity · 10.16 USD/year 10.16 Levoit Core 300 · Filters · 60 USD/year 60 Levoit Vital 200S-P · Filters · 80 USD/year 80 Levoit Core 300 · Total · 90.48 USD/year 90.48 Levoit Vital 200S-P · Total · 90.16 USD/year 90.16
Electricity assumes half speed, twelve hours a day, at $0.29/kWh. Filters use the most conservative manufacturer interval, which for both is six months. Prices are official retail in a Western market: US where the device is sold there, Europe where it is not. Other regions differ, sometimes sharply.
Because the running costs cancel out, the purchase price is the only real difference in what these devices cost you over time. Over five years, the Core 300 comes to $552 and the Vital to $640, a gap of $87 that is almost identical to the $89 difference in list price.
Five-year cost of ownership
0 140 280 420 560 700 Purchase Filters Electricity Total USD over 5 years Levoit Core 300 · Purchase · 99.99 USD over 5 years 99.99 Levoit Vital 200S-P · Purchase · 189 USD over 5 years 189 Levoit Core 300 · Filters · 300 USD over 5 years 300 Levoit Vital 200S-P · Filters · 400 USD over 5 years 400 Levoit Core 300 · Electricity · 152.42 USD over 5 years 152.42 Levoit Vital 200S-P · Electricity · 50.81 USD over 5 years 50.81 Levoit Core 300 · Total · 552.41 USD over 5 years 552.41 Levoit Vital 200S-P · Total · 639.81 USD over 5 years 639.81
Conclusion – Is the Levoit Core 300 or Vital 200S-P Better?
For most bedrooms and living areas, the Vital 200S-P is the better purifier, and it’s the one I chose to keep in our own bedroom. It moves around 50% more air at max speed, it’s 4 dBA quieter at the speed you’ll actually use, it can sit against a wall, and the VeSync app is excellent. If you have pets, the washable pre-filter and pet hair vent make the case even stronger.
However, the Core 300 still makes sense in a few situations. If your room is smaller (around 21 m² or less), if you want the most clean air for the lowest purchase price, or if you simply want a purifier you can set to one speed and forget, it does the job well and costs about $90 less to buy. Just keep in mind that it has no app or auto mode, and if you want those without stepping up to the Vital’s size, the Core 300S is the version I’d point you towards.
Since both devices cost about $90 a year to run, the decision comes down to the size of your room and how much the extra $89 is worth to you. Whichever you choose, budget for that $90 a year, and if you go with the Vital, set the fan speed yourself rather than relying on its auto mode.
Levoit Core 300 vs Vital 200S-P FAQ
Is the Levoit Vital 200S more powerful than the Core 300?
Yes. In my testing, the Vital 200S-P measured 387 m³/h at max speed against the Core 300’s 258 m³/h, and cleared a 29.4 m³ room in 19:31 instead of 26:42.
Which is quieter, the Core 300 or the Vital 200S-P?
At half speed, the Vital 200S-P, which measured 43 dBA against the Core 300’s 47 dBA. At max speed they’re almost identical, at 60 and 59 dBA.
Is the Levoit Vital 200S-P the same as the Vital 200S?
Yes. Levoit confirmed to me that the ‘-P’ is a retail designation rather than different hardware, and both use the same Vital 200S-RF filter.
Which is cheaper to run, the Core 300 or the Vital 200S-P?
Neither, as both cost about $90 a year in my calculations. The Core 300 uses more electricity, while the Vital’s filters cost more.
Does the Levoit Core 300 have an app or auto mode?
No. The Core 300 has no app, auto mode or air quality sensor. The Core 300S adds all three for around $50 more.
