Home /Air Purifier Reviews /AirFanta 3Pro vs 5Pro – Is…
AirFanta 3Pro vs 5Pro – Is the Extra $25 Worth It?
Since I reviewed it in December 2024, the AirFanta 3Pro has been my go-to recommendation for anyone who wants as much clean air as possible for the money. In November 2026, AirFanta released its successor, the 5Pro, and having now reviewed both, the obvious question is whether the newer model is worth the extra $25. In this AirFanta 3Pro vs 5Pro comparison, I want to answer exactly that.
Put simply, the two move a similar amount of air at full speed, so you aren’t paying for more cleaning power. The extra $25 buys a PM2.5 sensor, auto mode and a screen, a far safer and easier-to-assemble design, an AHAM-verified CADR, and filters rated to last a full year.
AirFanta sent me both devices for review. The 3Pro spent its two-week testing period in my office, while the 5Pro went through my current test room and has lived in our combined living room and kitchen since early November 2026, where it runs alongside the Mijia 6. One important difference is that I tested the 3Pro before building my current test room, and I no longer have it, so the two never went through the same test. Where I compare their performance below, I’ll let you know where the figures are from.
You can find the full detail in my AirFanta 3Pro review and my AirFanta 5Pro review. Below, I’ll compare the two on performance, noise and power, design, features and running costs, and then explain which one I’d buy.
I independently test air purifiers in the same sealed 29.4 m³ room at home. I fill it with incense smoke, switch the purifier on remotely and measure how quickly it clears the air, three runs at each speed, then record its noise from one metre and its power draw, so every result can be compared directly with the next.
Where a brand’s claims come from a lab test, I say which standard it used and how it differs from my own setup, and where I can’t measure something myself, such as filter certification, I lean on third-party results and name the source. You can read exactly how I score purifiers on my methodology page.
This post contains affiliate links. For more information, please refer to my affiliate disclaimer. AirFanta sent me both the 3Pro and the 5Pro for review, but this article is not sponsored. All opinions expressed in this post are my honest thoughts. I only recommend products that I genuinely believe in.
Both devices are built around the same idea, which is a pre-made Corsi-Rosenthal (CR) box. Four filter panels form the sides of a cube, and four PC-style fans on top pull air in through all four filters at once. Both use EPA11 (H11) filter media, rated at 95% single-pass efficiency for 0.3 micron particles, and AirFanta says the 5Pro’s usable filter area is 25% larger.
The headline figures, however, come from very different places. AirFanta rates the 3Pro at 413 CFM (702 m³/h), a figure that came from independent testing by community members rather than a certified lab, and HouseFresh’s own testing put it lower, at an estimated 353 CFM (600 m³/h). The 5Pro has gone through the AHAM Verifide program, with a certified smoke CADR of 379 CFM (644 m³/h), and in my own test room, it measured 730 m³/h at maximum speed.
SettingAirFanta 3ProAirFanta 5Pro
Maximum702 m³/h (AirFanta, community testing); ~600 m³/h (HouseFresh)730 m³/h measured; 644 m³/h AHAM smoke
Middle420 m³/h at speed 3 (AirFanta)437 m³/h at 50% (measured)
Low240 m³/h at speed 2 (AirFanta)223 m³/h at 25% (measured)
I did test the 3Pro myself in December 2024, in a 25.6 m³ bedroom with a different setup. At maximum speed, it took 17.3 minutes to bring that room below 5 µg/m³, against 9:38 for the 5Pro in my 29.4 m³ test room, but the two tests are too different to compare directly. Put together, the numbers don’t show a meaningful gap at the top end, and AirFanta’s own speed table for the 3Pro lines up closely with what I measured from the 5Pro at its middle and lower settings.
In other words, the 5Pro isn’t an upgrade in raw cleaning power. Its advantage is that its figures are certified, and that I’ve measured them under the same conditions as the other purifiers in my current test room. If you want to work out how much CADR your own room needs, my air purifier room size calculator will do the maths for you, and either device covers a living room, a large bedroom or a small apartment comfortably.
Purchase the AirFanta 5Pro from AirFanta
Purchase the AirFanta 3Pro from AirFanta
Noise & Power Consumption
Both devices use four 140mm fans, so it’s no surprise that they sound similar. The main complication is that I measured the 3Pro from 30cm and 2 metres, while every purifier I’ve tested since (including the 5Pro) is measured from one metre. Working between the two 3Pro distances gives a reasonable estimate of what it would read at one metre:
SettingAirFanta 3Pro (30cm / 2m, measured)AirFanta 3Pro (1m, estimated)AirFanta 5Pro (1m, measured)
Low (speed 2 / 25%)48.5 / 39.8 dBA~43 dBA43 dBA
Middle (speed 3 / 50%)57 / 50 dBA~53 dBA50 dBA
Maximum71.5 / 61.6 dBA~65 dBA63 dBA
At their lowest useful settings, the two are effectively identical, at around 43 dBA while delivering a little over 200 m³/h. At the middle setting, the 5Pro is around 3 dBA quieter while (going by AirFanta’s 3Pro figures) delivering a similar amount of air, and at maximum, it’s around 2 dBA quieter. These are small differences, and both are loud at full speed. That’s why, with the 3Pro, I usually found myself using speed 2 or 3, and with the 5Pro, I’ve settled on 35% in our living room, where I can’t separate it from the room’s own background noise.
Power consumption is low on both. I measured the 3Pro at 2.2W on speed 1, 11.1W on speed 3 and 33.2W at maximum, and the 5Pro at 2W at 25%, 10W at 50% and 40W at maximum. The 5Pro draws a little more at full speed, but at their middle settings, both cost around $13-14 a year to run, using my usual assumptions (half speed, twelve hours a day, at $0.29/kWh). Electricity, in short, isn’t a reason to pick one over the other.
Design & Assembly
Design is where the two devices differ most. Both arrive as six flat plates (a base, four filters and a top cover with the fans), but assembling them is a very different experience. With the 3Pro, the fiddly part was keeping all four filters upright while lowering the fan assembly on top, and there were times when I needed someone to hold them in place for me. The 5Pro solves this with 32 magnets embedded in the plastic, so the panels snap into place, the whole process takes about a minute, and two buttons release the top cover when you want to take it apart.
The fans are the other big change. On the 3Pro, they sit on top of the device behind a wire bracket, and in my review, I suggested placing it up high if you have children around. On the 5Pro, they’re recessed inside the frame, and the power cable can’t be plugged in unless the top cover is fully seated (and the cover can’t be removed while it’s plugged in). With a child who will be walking in a few months, that matters to me more than it did when I reviewed the 3Pro.
The 5Pro’s fans are also easier to keep running. On the 3Pro, all four fans were soldered together, so one failed fan meant replacing the whole assembly. The 5Pro’s fans are instead screwed in individually, so you can swap out a single fan (AirFanta quotes $15-20 shipped for a pair), and each one now spins on a machined copper bearing tube rather than a plastic one, which should help it survive a knock in transit.
Assembled size33 x 33 x 33cm33 x 33 x 39cm
Packed down33 x 33 x 14cm stackstack of six plates (fits my carry-on)
Assemblyslots and velcro32 magnets, release buttons
Fansfour 140mm, on top behind a wire bracketfour 140mm, recessed, individually replaceable
Powerpower adapter with an in-line speed dialremovable barrel cable with a safety interlock
Both are still compact for how much air they move, and both pack down flat. The 3Pro stacks to just 14cm high, while the 5Pro is 6cm taller when assembled, but I can confirm it still fits in my carry-on suitcase (albeit taking up a lot of room). As for looks, the 3Pro is unmistakably a CR box, with exposed filter media and fans on top, which I don’t mind. The 5Pro hides its filters behind plastic grilles and looks like a finished product rather than a DIY project.
Sensor & Features
The 3Pro is as simple as an air purifier gets. There’s no sensor, no screen and no auto mode, and the only control is a six-speed dial on a small controller on the power cable (earlier units used a voltage dial instead). It works well, and I’m a fan of that straightforward approach, but it’s all you get.
The 5Pro moves the dial to the top of the device, where it’s notched in 5% steps from 25% to 100%, and pressing it turns the purifier on or off. Beside it is a small recessed screen showing the fan speed and the PM2.5 concentration in µg/m³ (a raw reading rather than an AQI), with a coloured border that changes through six bands. Since there’s no connectivity, I could only compare the 5Pro’s sensor with my dedicated air quality monitors visually, but it generally read within 5-10% of them.
Holding the dial for three seconds switches to auto mode, which runs at 25% below 15 µg/m³ and ramps up through 50%, 65% and 80% to 100% above 150 µg/m³. Auto mode is not bad, but it’s too lenient for me, as I aim for under 5 µg/m³ at all times, so I leave the 5Pro in manual mode and pick the speed myself. The 5Pro also remembers its last speed and mode when it loses power, which means a smart plug can give you simple schedules and automations.
Neither device has an app, Wi-Fi or a remote. If you want any of those, you’ll need to look elsewhere, such as the Mijia Smart Air Purifier 6.
Filters & Running Costs
The 3Pro costs $164.99 with the standard filters or $179.99 with carbon filters, while the 5Pro costs $189.99 or $199.99. That’s a gap of $25, or $20 for the carbon versions. On price per m³/h of clean air, they’re almost level at around $0.25 each, which makes them the two best-value purifiers I’ve reviewed by that measure.
Replacement filters cost almost the same, too. A set of four costs $57 for the 3Pro and $59 for the 5Pro, or $75 for either with carbon. The filters aren’t interchangeable, though, as the 5Pro’s panels are taller, so AirFanta sells a separate set for each.
The bigger difference is how long AirFanta says those filters last. It rates the 5Pro’s for 12 months but the 3Pro’s for 6-12 months, and since running costs depend almost entirely on filters, that range decides which device is cheaper to own. If the 3Pro’s filters last a full year, both cost around $71-72 a year to run, including electricity. If you replace the 3Pro’s every six months, it costs around $128 a year against $72 for the 5Pro, and the 3Pro’s $25 saving is gone within the first year.
Price (standard / carbon)$164.99 / $179.99$189.99 / $199.99
Filter set (standard / carbon)$57 / $75$59 / $75
Filter life (AirFanta)6-12 months12 months
Running cost per year~$71 (12-month filters) to ~$128 (6-month filters)~$72
Cost over five years~$520 to ~$805~$550
In my 3Pro review, I estimated that most people would replace its filters every nine months or so, which works out to around $76 a year. At that rate, the 3Pro costs around $90 a year to run and $615 over five years, so the 5Pro only costs more to own if the 3Pro’s filters really do last a full year, and even then by only around $30 over five years.
Conclusion – Should You Buy the AirFanta 3Pro or 5Pro?
If raw cleaning power per dollar is all you care about, the 3Pro is still a great purifier. It moves a similar amount of air to the 5Pro for $25 less, it draws less power at full speed, and if you don’t mind the CR box look, it does the main job just as well. It suits an adult-only space or anywhere you can keep it out of reach, and if you’re happy to set the speed yourself, you won’t miss the sensor.
However, for most people, I would pay the difference for the 5Pro. You get a PM2.5 sensor that reads close to my dedicated monitors, a screen, auto mode, magnets that make assembly easy, fans that are safer around children and pets and can be replaced individually, an AHAM-verified CADR, and filters rated for a full year. It’s also slightly quieter at the settings you’ll actually use, and once filters are included, it costs about the same to own, or less if the 3Pro’s filters need replacing more than once a year.
The 3Pro only stays the cheaper of the two if its filters last a full year, so if you buy one, it’s worth keeping an eye on how quickly yours discolour. Whichever one you choose, give it space on all four sides (AirFanta recommends 38cm for the 5Pro), as both pull air in through every filter.
Purchase the AirFanta 5Pro from Amazon
Find the AirFanta 3Pro in the AirFanta Amazon store
AirFanta 3Pro vs 5Pro FAQ
Is the AirFanta 5Pro more powerful than the 3Pro?
Not meaningfully. The 3Pro is rated at 702 m³/h from community testing (HouseFresh estimated around 600 m³/h), while the 5Pro has an AHAM smoke CADR of 644 m³/h and measured 730 m³/h in my test room.
Is the AirFanta 5Pro quieter than the 3Pro?
Slightly. At one metre, I measured the 5Pro at 50 dBA at 50% and 63 dBA at maximum, against an estimated 53 dBA and 65 dBA for the 3Pro at its middle and maximum speeds.
Do 3Pro filters fit the 5Pro?
No. The 5Pro is 6cm taller, and AirFanta sells separate filter sets for each device, at $57 for the 3Pro and $59 for the 5Pro (or $75 for either with carbon).
Is the AirFanta 3Pro still worth buying?
Yes, if you want the most clean air for the lowest upfront price and don’t need a sensor or auto mode. Just factor in the filters, as replacing them every six months makes it more expensive to own than the 5Pro.
Can you travel with the AirFanta 3Pro or 5Pro?
Yes. Both come apart into six flat plates. The 3Pro stacks to 14cm high, and the 5Pro fits in my carry-on suitcase, although it takes up a lot of room.
