Home /Air Purifier Reviews /Xiaomi 4 Lite vs 4 Compact…
Xiaomi 4 Lite vs 4 Compact – Which Air Purifier Should You Buy?
I’ve now reviewed both the Xiaomi Smart Air Purifier 4 Lite and the Xiaomi Smart Air Purifier 4 Compact, and the two devices sit right next to each other in Xiaomi’s lineup. The 4 Compact is the smallest and cheapest purifier Xiaomi makes, while the 4 Lite is one step up and is designed for bedrooms and small living areas. They share the same Mi Home app, they look similar on paper, and in some markets the price gap between them is small enough to make the Xiaomi 4 Lite vs 4 Compact decision a difficult one.
In short, the 4 Lite is the one to get unless your room is small. It measured 350 m³/h against the 4 Compact’s 216 m³/h in the same room and shows real PM2.5 readings, while the 4 Compact earns its place on a shelf, in a small office or as a second purifier.
I bought both devices myself here in the Philippines, and I’ve used the 4 Lite since January 2026 and the 4 Compact since around April. More importantly, I ran both through exactly the same test in the same room, which lets me compare them far more directly than I can with most purifiers.
If you want the full detail on either device, you can find my Xiaomi Smart Air Purifier 4 Lite review and my 4 Compact review here. In this article, I will compare the two on performance, noise, sensors, design and cost before giving my recommendation on which one to buy.
I independently test air purifiers in the same sealed 29.4 m³ room at home. I fill it with incense smoke, switch the purifier on remotely and measure how quickly it clears the air, three runs at each speed, then record its noise from one metre and its power draw, so every result can be compared directly with the next.
Where a brand’s claims come from a lab test, I say which standard it used and how it differs from my own setup, and where I can’t measure something myself, such as filter certification, I lean on third-party results and name the source. You can read exactly how I score purifiers on my methodology page.
Xiaomi Purifier Performance
The biggest difference between these two devices is how much air they can clean, so that’s where I want to start. Xiaomi rates the 4 Lite at a CADR (clean air delivery rate – how much clean air the purifier produces each hour) of 360 m³/h for rooms of 25-43 m². The 4 Compact is rated at 230 m³/h for rooms of 16-27 m², which makes the 4 Lite around 57% more powerful on paper. If you’re not sure which of those ranges your own room falls into, my room size calculator will work out the CADR it needs.
To see how they actually perform, I tested both in my 29.4 m³ spare bedroom. I burned incense until PM2.5 reached around 500 µg/m³, remotely triggered the purifier so I wasn’t in the room, and timed how long it took for the concentration to fall below 5 µg/m³. I ran max and half speed three times each, and every reading came from the same AirGradient ONE I-9PSL sitting in the room with the purifier.
4 Lite vs 4 Compact at max speed
4 Lite vs 4 Compact at max speed Decay in µg/m³ of 3 series (Xiaomi 4 Lite, max speed; Xiaomi 4 Compact, max speed; No purifier, room alone) against time in minutes, measured in a 29.4 m³ room. 0 100 200 300 400 500 0 5 10 15 20 25 30 35 40 PM2.5 (µg/m³) Minutes elapsed
Shading spans the fastest and slowest run at each moment.
Key figures, mean of runs
Series Runs Measured CADR To 50% To 90% To 99%
Xiaomi 4 Lite, max speed 3 350 m³/h 3:56 11:36 21:02
Xiaomi 4 Compact, max speed 3 216 m³/h 6:12 18:01 32:01
Measured CADR is the median of 3 runs, fitted to the exponential part of each decay curve in a 29.4 m³ room. A real room isn't a sealed test chamber, so my figures won't line up exactly with a lab result, and a difference here doesn't mean the manufacturer is wrong.
29.4 m³ · AirGradient ONE I-9PSL (factory calibrated) · Download xiaomi 4 lite, max speed data (CSV) · Download xiaomi 4 compact, max speed data (CSV) · Download no purifier, room alone data (CSV)
At max speed, the 4 Lite brought the room below 5 µg/m³ in 21 minutes, while the 4 Compact needed 32. That works out to 350 m³/h of measured clean air delivery for the 4 Lite against 216 m³/h for the 4 Compact, so the 4 Lite moves around 62% more air. If you only look at how long it took to remove 90% of the pollution, the gap is 11:36 against 18:01.
Both devices came in slightly under Xiaomi’s claims (350 against 360, and 216 against 230). A small difference like this is expected and doesn’t mean Xiaomi’s claims are false. My spare bedroom is a real room with furniture and gaps rather than a sealed test chamber, and incense isn’t the same as the particles used in official testing, so landing within a few percent of the claim is about as close as you’ll get.
Claimed vs measured CADR
0 80 160 240 320 400 Claimed Max Medium m³/h Xiaomi 4 Lite · Claimed · 360 m³/h 360 Xiaomi 4 Compact · Claimed · 230 m³/h 230 Xiaomi 4 Lite · Max · 350 m³/h 350 Xiaomi 4 Compact · Max · 216 m³/h 216 Xiaomi 4 Lite · Medium · 155 m³/h 155 Xiaomi 4 Compact · Medium · 141 m³/h 141
Interestingly, most of that gap disappears at half speed. Here, the 4 Lite measured 155 m³/h against the 4 Compact’s 141 m³/h, and they took 45 and 54 minutes respectively to clean the room. If you mostly run your purifier at half speed, which is the setting most people leave a purifier on, the 4 Lite’s advantage is closer to 10% than 60%. Where the 4 Lite really pulls ahead is when you need to clear a room quickly at max speed.
4 Lite vs 4 Compact at half speed
4 Lite vs 4 Compact at half speed Decay in µg/m³ of 3 series (Xiaomi 4 Lite, half speed; Xiaomi 4 Compact, half speed; No purifier, room alone) against time in minutes, measured in a 29.4 m³ room. 0 100 200 300 400 500 0 10 20 30 40 50 60 PM2.5 (µg/m³) Minutes elapsed
Xiaomi 4 Lite, half speed 3 155 m³/h 8:17 23:54 45:03
Xiaomi 4 Compact, half speed 3 141 m³/h 9:33 27:03 54:23
29.4 m³ · AirGradient ONE I-9PSL (factory calibrated) · Download xiaomi 4 lite, half speed data (CSV) · Download xiaomi 4 compact, half speed data (CSV) · Download no purifier, room alone data (CSV)
Unfortunately, the automatic and sleep modes are weak on both devices. In my testing, the 4 Lite’s auto mode couldn’t bring the room down to 1 µg/m³ even after 40 minutes, and the 4 Compact’s auto and sleep modes both stalled at around 40-50 µg/m³ after two hours. Xiaomi’s auto thresholds are simply too lenient, so on either device I would recommend setting the speed yourself.
Search Amazon for the Xiaomi Smart Air Purifier 4 Lite
Search Amazon for the Xiaomi Smart Air Purifier 4 Compact
Noise
Measured noise
0 13 26 39 52 65 Max Medium dBA Xiaomi 4 Lite · Max · 58 dBA 58 Xiaomi 4 Compact · Max · 56 dBA 56 Xiaomi 4 Lite · Medium · 44 dBA 44 Xiaomi 4 Compact · Medium · 45 dBA 45
Sleep is left out: both units read within a couple of dBA of the room's own noise floor at their lowest setting, which measures the room rather than the purifier.
Since both of these devices will likely spend their time in a room you sleep or work in, noise matters almost as much as speed. I measured both at max and half speed, and there’s very little between them. At max speed, the 4 Compact is the quieter of the two at 56 dBA against the 4 Lite’s 58 dBA. At half speed, the order flips and the 4 Lite reads 44 dBA against the 4 Compact’s 45 dBA.
Differences of 1-2 dBA won’t decide a purchase. On paper, the 4 Compact is much quieter in sleep mode (Xiaomi quotes 20 dBA against 33.4 dBA for the 4 Lite), but my room’s own noise floor sits above both figures, so I can’t confirm either. It’s also worth keeping in mind that the 4 Compact’s smaller fan has to spin faster to move air, which tends to produce a higher-pitched sound than a larger, slower fan.
Sensors & Smart Features
Outside of performance, the sensor is where the two devices differ most, and it affects far more than the number on the screen. Where the 4 Lite uses a laser particle sensor, the 4 Compact opts for an infrared sensor (made by Pulse Sensor), which is generally less sensitive to fine particles.
The 4 Lite shows PM2.5 in µg/m³, along with temperature and humidity, both on its screen and in the Mi Home app. In my side-by-side testing it tracked trends reasonably well against my calibrated AirGradient ONE monitors, generally reading slightly higher and occasionally spiking for a few readings without any real change in the room. It won’t replace a dedicated air quality monitor, but it’s good enough to be useful. The one disappointment is that the app doesn’t keep any historical data.
The 4 Compact doesn’t show a number at all. Instead, you get a status label such as “Good” or “Poor”, and assuming it uses the same thresholds as the 4 Lite, “Good” covers anything under 35 µg/m³. For comparison, the WHO recommends staying under 15 µg/m³ over a 24-hour period.
This has a knock-on effect on automations. With the 4 Lite, you can trigger an automation from its PM2.5 reading, for example switching to manual mode (preset to max speed) when the concentration goes above 15 µg/m³. With the 4 Compact, the only triggers available are “On” and “Off”, so you can’t build your own auto mode unless you have another Xiaomi device feeding PM2.5 readings into Mi Home. I run my 4 Compact’s automations from the Mijia Smart Air Purifier 6, but many people won’t have that option. Voice control is equally basic on both, and Alexa can only switch them on and off or change between Auto, Sleep and Manual modes.
Mi Home Automation
Design & Size
Both devices follow Xiaomi’s minimalist design, but the 4 Compact’s size is its biggest advantage. It measures 220mm in diameter and 355mm tall, and at 2.2kg it’s light enough to sit on a shelf or desk, which is how I use mine. That’s something the 4 Lite can’t match.
Each device uses its own cylindrical filter, and neither filter fits the other device (or the Mijia 6). To change the 4 Lite’s filter, you press the two buttons on its sides and lift the top half off. On the 4 Compact, you twist a handle on the bottom and the filter slides out. Both are straightforward, and the 4 Compact’s filter also includes an RFID tag that the 4 Lite’s doesn’t have.
Each has its own small annoyances too. The 4 Lite’s fan can’t easily be reached for cleaning without removing four screws, and its buttons on top have a slightly unresponsive feel. The 4 Compact’s touch buttons sit on top of the device, and my cats like to sit there, frequently turning it off or switching modes. I now keep the screen locked, which solves the problem as long as I remember to re-lock it.
Pricing & Running Costs
What each one costs to buy
0 50 100 150 200 250 Xiaomi 4 Lite Xiaomi 4 Compact USD Xiaomi 4 Lite · 199 USD 199 Xiaomi 4 Compact · 119.99 USD 119.99
Price is where this comparison gets complicated, because it depends heavily on where you live. I bought the 4 Compact for ₱3,999 (around $66), and the 4 Lite usually sells here for around ₱7,500 (around $115). In North America and Europe, you’re typically looking at $99-120 for the 4 Compact, while the 4 Lite sells for nearer $199 in Europe. To keep both devices on the same basis, the charts in this section use those Western prices rather than the prices I paid.
Looking at price against measured CADR, the two devices are very evenly matched. At Western prices, you pay around $0.56 per m³/h of clean air for the 4 Compact and $0.57 for the 4 Lite. Here in the Philippines, the 4 Compact is slightly better value at around ₱19 per m³/h against ₱21 for the 4 Lite. In other words, the extra money for the 4 Lite goes almost entirely towards extra cleaning power.
Price per m³/h of measured CADR
0 0.13 0.26 0.39 0.52 0.65 Xiaomi 4 Lite Xiaomi 4 Compact USD per m³/h Xiaomi 4 Lite · 0.57 USD per m³/h 0.57 Xiaomi 4 Compact · 0.56 USD per m³/h 0.56
Running costs are almost identical as well. Both devices draw 9 W at half speed (32 W and 25 W at max), and Xiaomi recommends replacing the filters every 6-12 months. Here, 4 Lite filters cost ₱1,000-1,400 ($17-25) and 4 Compact filters around ₱1,000, although on Amazon the 4 Compact’s can cost up to $40. On the chart’s assumptions, both devices cost about $61 a year to run.
What each costs to run for a year
0 14 28 42 56 70 Electricity Filters Total USD/year Xiaomi 4 Lite · Electricity · 11.43 USD/year 11.43 Xiaomi 4 Compact · Electricity · 11.43 USD/year 11.43 Xiaomi 4 Lite · Filters · 50 USD/year 50 Xiaomi 4 Compact · Filters · 50 USD/year 50 Xiaomi 4 Lite · Total · 61.43 USD/year 61.43 Xiaomi 4 Compact · Total · 61.43 USD/year 61.43
Electricity assumes half speed, twelve hours a day, at $0.29/kWh. Filters use the most conservative manufacturer interval, which for both is six months. Prices are official retail in a Western market: US where the device is sold there, Europe where it is not. Other regions differ, sometimes sharply.
Conclusion – Is the Xiaomi 4 Lite or 4 Compact Better?
For most people, the 4 Lite is the better purifier. It moves around 62% more air at max speed, shows real PM2.5 readings, and lets you build automations that make up for Xiaomi’s weak auto mode. If you want a purifier for a master bedroom, a studio apartment or a small living area, the 4 Lite is the one I would buy.
However, the 4 Compact still makes sense in a few situations. If your room is small (my office is roughly 4 x 4 metres), if you need something that sits on a shelf or desk, or if you want a second purifier to support a larger one, it does the job for less money. It also works on a strict budget, as long as you’re happy to control the fan speed yourself and keep the room closed while it runs.
Since you pay roughly the same for each m³/h of clean air, the decision mostly comes down to the size of your room. Before buying, check the price gap where you live. If it’s small, step up to the 4 Lite, and if it’s wide, the 4 Compact stands on its own, unless you need the 4 Lite’s real PM2.5 readings.
Whichever one you choose, set the speed manually or through automations rather than relying on auto mode, as neither device’s auto mode is aggressive enough to keep a room clean.
Xiaomi 4 Lite vs 4 Compact FAQ
Is the Xiaomi 4 Lite more powerful than the 4 Compact?
Yes. In my testing, the 4 Lite delivered 350 m³/h at max speed against the 4 Compact’s 216 m³/h, and cleaned a 29.4 m³ room in 21 minutes instead of 32.
Can the 4 Lite and 4 Compact use the same filters?
No. Each device uses its own cylindrical filter, and neither fits the other or the Mijia Smart Air Purifier 6.
Which is quieter, the 4 Lite or the 4 Compact?
They’re almost identical. I measured 58 dBA (4 Lite) and 56 dBA (4 Compact) at max speed, and 44 dBA and 45 dBA at half speed.
Do both devices show PM2.5 readings?
No. The 4 Lite shows PM2.5 in µg/m³ on its screen and in the Mi Home app, while the 4 Compact only shows a status label such as “Good” or “Poor”.
Which is better for a bedroom?
For a master bedroom, the 4 Lite. The 4 Compact is better suited to a small bedroom or home office, especially one you can keep closed.
