Happy Masks is a U.S-based company that recently came on my radar when I was researching nanofibre masks. Soon after, a few readers contacted me asking if I would be able to do a review as they were interested in purchasing the mask. Today I want to bring you my Happy Masks review.
Happy Masks advertise some quite interesting features. The most important of these features is the very lightweight nanofibre filter that retains efficiency even after being washed. The mask is also very breathable, has a beak design so it doesn’t interfere with speaking, and has very high tested filtration results.
With these features, I quickly became interested in the mask and wanted to try it myself. Happy Masks was kind enough to send me a mask so that I could write my thoughts and share some of the science behind the mask.
Happy Masks sells two types of masks, the Pro Series and the Base Series. Both masks use the same filter, but the design of the masks is different and the Pro series is designed to last longer. This review is of the Pro Series mask from Happy Masks.
If you’ve tried these masks yourself then I would love to hear your thoughts in the comments below. I always value other opinions and I would be interested to see what others have experienced with Happy Masks. With that being said, this is my Happy Masks review.
Please note: There is some confusion as there are two mask brands – Happy Masks, and Happy Mask (no plural). This review is for Happy Masks found at HappyMasks.com. I have NOT reviewed masks from happy-mask.com.
This post contains affiliate links. For more information, please refer to my affiliate disclaimer. I was sent a product for review, but the article is not sponsored. All opinions expressed in this post are my honest thoughts. I only recommend products that I truly believe in.
Information on this blog is for informational purposes only. Readers are encouraged to confirm the information herein with other sources. Furthermore, this information is not intended to replace medical advice from professionals. This website assumes no responsibility for the accuracy of information and information is subject to change without notice. Devices mentioned on this website are not medical devices and do not guarantee protection.
Fit and filtration are the two most important factors of any mask and they both go hand in hand. Filtration testing is important to see how effective a filter actually is, and a good fit is required to make sure that air actually passes through the filter.
In this section, I will discuss the lab results that I was provided by Happy Masks. I will have a look into what they mean and how they can be interpreted. Further, I will also discuss a few unique aspects of the mask.
It’s important to note that this testing applies only to the filter, not the mask itself. Further, as previously mentioned it’s vital to make sure that the mask is fitted as well as possible so as to minimise leaks – leaks indicate that not all of the air is being filtered, meaning that you are breathing unfiltered air.
Happy Masks have one big advantage when it comes to filtration and that is due to the fact that the masks use a nanofibre membrane filter. Nanofibre filters can be found in some reusable cloth masks, but they are still much less common than cheaper to produce melt blown filters.
Meltblown filters are cheaper to produce and easier to make, and that is why the majority of masks on the market rely on them. However, they also rely very heavily on electrostatic attraction – something that can be lost due to a variety of factors such as moisture in exhaled air.
On top of this, Meltblown filters can’t be washed and require very specific cleaning methods to retain filtration efficacy. Even then, they drop in efficacy far more quickly than nanofibre filters which rely much more on other filtration mechanisms.
I recently interviewed Revolution Fibres on the benefits of nanofibre filters and I recommend reading that article if you would like to learn more. In brief, nanofibre filters typically are usable for longer, have much lower breathing resistance, can be washed more easily, and retain more filtering efficacy through washes. The use of a nanofibre filter in Happy Masks is very advantageous.
In fact, I was shown test results from OSH, a Taiwanese respirator testing laboratory. In the tests, unwashed (new) filters were compared to filters that had undergone 50 washes. I was told that the masks were washed for 3 minutes in water with a drop of dish detergent.
The masks were then removed from the water, rinsed, and left to air dry. 5 masks were tested this way, and each was exposed to this process 50 times. These 5 masks were then tested against a sample of 5 masks that had not been washed at all. The end results showed no difference in filtration efficacy between the unwashed masks and those that were washed 50 times.
This is a very impressive result and it’s in line with what I expect from nanofibre filters. Since the filter is built into Happy Masks (and can’t be removed or replaced), this is especially important. The filter is good for around 250 hours of wear and can be washed in detergent when needed.
In lab tests, the filter has also performed very well and the filter is one of the most capable that I’ve seen. The mask has been tested for NaCL (a particle filtration efficiency test), BFE (bacteria filtration efficiency), and VFE (viral filtration efficiency). BFE and VFE testing was carried out by Nelson Labs and NaCL testing by TTRI (Taiwan Textile Research Institute).
For both the BFE and VFE tests (with 5 samples tested) the filter achieved > 99.9% filtration. This was carried out using particles with a mean particle size of 3.1μm at a flow rate of 28.3 litres/minute. In all of the VFE tests, there were no detected plaques downstream of the mask.
In the NaCL testing carried out by TTRI 10 samples were tested achieving an average filtration rate of 99.97%. The lowest recorded result out of the tested samples was 99.93%. This testing was carried out at a flow rate of 85l/min and with particles 0.075μm.
Particle Type | Filtration |
NaCL | ≥ 99.93% |
VFE | > 99.9% |
BFE | > 99.9% |
Due to the nanofibre construction of the filter, the mask is also exceptionally light and provides relatively low breathing resistance. The only other mask I have tried with lower breathing resistance is the Bloo Mask – a mask that also uses a nanofibre filter.
Happy Masks have a very simple design and this is one of their strengths. The mask is very lightweight and it’s made from materials that help it achieve this. The nanofibre filter and mask skin are very thin, as are the ear loops.
This helps make the mask very easy to wear. It’s a mask that can easily be donned and doffed and wearing the mask feels much more freeing than wearing a larger mask such as the AirFlex Mask or a Cambridge Mask.
Despite being so light and thin, the mask doesn’t suffer from mask collapse. This occurs with many lighter masks as they tend to be made from less sturdy materials – materials that can easily interfere with breathing. Happy Masks utilise a ‘beak design’ with the front of the mask protruding a few centimetres in order to prevent difficulties breathing.
Due to this, I also found talking in my Happy Masks to be much easier than with many other masks. I never got the interior layer in my mouth and this is a big advantage as there aren’t many things more frustrating than accidentally eating your mask!
There is a thin wire nose-piece near the top of the mask which is meant to allow for a tighter fit around the wearer’s nose. The wire is very bendable and is easy to adjust. The piece of wire goes around my nose and protrudes onto my cheeks slightly, but not much.
Following the light and simple design of the mask, the ear loops are made from an elastic string that is very lightweight. Both earloops come with a small bead on them allowing the user to make some adjustments to the tightness of the mask.
These strings are thin, however, and can cause some pain behind the ears after long periods of wear. This is somewhat offset by how light the mask is though, and I found the pain to be less than some other masks that rely on ear-loops. However, I prefer masks that use neckbands (such as Purar Masks) and headbands.
Also worth noting is that the materials used don’t appear to have any strong scents. While it may sound unusual, I’ve come across many masks that have odd scents when they are new. While these don’t prevent me from wearing masks, they can be uncomfortable when initially donning a mask. Luckily, Happy Masks don’t appear to have any such issues.
While filtration is often the aspect that many customers focus on when purchasing a mask, the fit is just as important if not more so. A mask that isn’t fitted correctly will not filter air and in that case, the actual filtration specifications of a mask are useless.
As I mentioned in the design section, Happy Masks rely on the wire nose-piece and earloops to achieve a good fit. There is no foam around the nose area, and a secure seal relies entirely on the wire. The ear loops are adjustable and allow for some degree of fitting the mask.
I am using the medium mask and I found that to achieve a decent fit I had to pull the beads on the ear loops about halfway up the elastic string. It might just be my face shape, but I had to essentially halve the length of the ear loops to achieve a fit I was comfortable with. Luckily, that’s no big deal since the loops are designed to be adjusted.
When tightened, the mask sits quite deep under my chin – it sits about 3cm back from my jawline. This appears to be a good design choice as I have noticed no leaking on the bottom of the mask. Since it sits quite far back, it’s also a sturdy fit that doesn’t move when I am doing physical activities.
The most common area to experience leaks with cloth masks is around the nose. Since this is the most varied surface with large angles, it’s hard to achieve a perfect fit here. On the other hand, the cheeks and chin are quite flat and allow for a far less difficult seal.
Even when I tightened the mask I had some leaks around my upper nose area. While I was able to get the mask to seal around the sides of my nose, I had difficulty with the top-most point of the mask. I could still feel the majority of the air exiting through the filter, but I could feel warm air exiting near my eyes.
This leak did become much smaller after adjusting the mask properly and tightening it as I mentioned earlier. However, it is still there even after spending a good amount of time adjusting the mask and trying to remove it. In saying that, I have experienced very few cloth masks where I have been able to fully remove leaks around the nose area.
I would be interested in testing the mask with either a longer piece of wire that is a few centimetres longer on both sides or with a piece of memory foam around the nose. I’m unsure if these would remove the leak entirely, but I would be interested to see the results. I have been told that Happy Masks is currently testing a longer piece of wire based on customer feedback.
June 2021 update: Happy Masks has since released an updated version of the mask that features a longer nose-piece and that is shaped slightly differently. After testing this mask over a few weeks I have found the fit to be much better than on the model that I initially reviewed. While there are still minor leaks, the fit has been improved significantly. I will keep my initial thoughts here as I believe that it shows how Happy Masks is open to customer feedback and how they are constantly working to improve their masks.
I found the beads on the earloops to be surprisingly sturdy and they didn’t move much even after doing physical activities with the mask. Often beads move a bit during wear and loosen the mask, but my Happy Masks mask does not have such an issue.
Overall, I found that the fit was decent for a cloth mask. While I wasn’t able to fully remove the leak near my nose, I was able to minimise it. Further, there are very few cloth masks that I am able to fully remove the leaks on – it’s very hard to create a mask that fits everyone perfectly.
Other than the aforementioned area the mask didn’t leak in my experience. Both the bottom and sides fit well and sat close to my face creating an effective seal. Something interesting that I noticed is that it’s much harder to identify leaks on this mask compared to most other masks due to the low breathing resistance of the filter.
Happy Masks do not feature removable filters. As such, the filters can’t be replaced and the whole mask should be replaced once it gets damaged or reaches the end of its lifespan. Fortunately, due to the filter design, the mask can be washed.
When washing the mask, make sure to hand wash. The masks should never be machine washed as they are delicate and require soft handling. For the exact washing procedure, Happy Masks has a short one minute Youtube video explaining the process.
The masks have been tested for filtration efficacy after 50 washes and there was no drop in filtration. This means that provided you are washing the mask as the video shows, there should be no need to worry about a loss of efficiency. However, if the mask gets damaged or the filter becomes difficult to breathe through the mask should be replaced.
Further, Happy Masks should be replaced after 250 hours of wear. If you are wearing the mask for 2 hours every day, this equates to around 4 months of wear. While this does depend on local air quality conditions, you should be able to expect to get around this lifespan from each Happy Mask.
The masks themselves cost $24 for the Pro Series. This means that you are looking at around $1 per 10 hours or 10 cents per hour of wear. In the long run, this will come out much cheaper than disposable masks. Even better, Happy Masks have significantly better filtration efficacy than most disposable masks.
Out of all of the reusable cloth masks that I have tested on this website, Happy Masks have some of the best filters. Not just in regards to filtration in lab tests, but also in regards to breathability, lifespan and overall comfort.
I believe that nanofibre filters are the way of the future when it comes to masks and filtration. I am very happy to see this technology being used in Happy Masks as it’s still much less common in reusable masks than melt blown technology.
Happy Masks are also very light and are very easy to wear. This is one of the least intrusive masks that I have worn, and it’s easy to put on for a short trip outside such as when I supermarket shopping. On the other hand, it’s also proven quite comfortable over longer periods of wear.
I am also very happy to see that Happy Masks was willing to listen to customer feedback and to improve their masks based on common complaints. They were quick to act on feedback about the wire nose-piece and to try to solve the issue. While I do still encounter minor leaks around the nose (especially when active), the fit is significantly better than on the previous iteration of the mask.
In fairness, I want to mention again that there are very few masks where I am unable to fully remove leaks. I have only used 3 or 4 cloth masks that allow me to fully remove leaks and even these encounter issues at times (such as when exercising). Everyone’s face is different and this mask may fit others better or worse than me.
The sturdy ‘beak’ design of the mask also means that there is little mask collapse and I found speaking in this mask to be very easy. For this reason (along with the low breathing resistance) I feel like this would be a good mask for exercising in provided that it fits correctly.
Finally, I also want to mention that I believe this mask would be a good choice for children. Realistically, children’s masks are hit and miss because you will never be able to achieve a leak-free seal on children – they are just too active and love to touch/adjust their masks. Happy Masks are quite loose-fitting but are still able to achieve a decent seal.
Happy Masks FAQ
Do Happy Masks Have an Official Rating?
Currently, Happy Masks have no official certification (N95, KN95, KF94, etc). However, they do have third-party testing from Nelson Labs and TTRI.
Have Happy Masks Been Lab Tested?
Yes. Happy Masks have had NaCL filtration testing done by TTRI and VFE and BFE testing has been carried out by Nelson Labs.
Do Happy Masks Use Replaceable Filters?
No. Happy Masks have a nanofibre filter sewn into the mask. As such, the filter can’t be replaced.
What Is the Lifespan of Happy Masks?
The lifespan of Happy Mask’s Pro Series is around 250 hours of wear.
Can Happy Masks be Washed?
Yes! The masks can be hand washed and have been shown to retain filtering efficiency after being washed 50 times.
Hi Ethan,
Thank you so much for your reviews. Logical and organized. Very refreshing read.
I have a question- i live in an area that gets hot in the summers. 95° – 110F, 35- 43 C,. Do you have experience with wearing masks in heat? What masks might you reach for on a hot day. This Mask had the word Light quite a bit. We can wear valve masks outdoors atm. So I might try one of those also. I am interested in any light you have on the subject.
Thank you so much!
Hello Jeanine,
Thank you for your kind words! I do have some experience wearing masks in heat – Seoul summers can reach about 40 degrees and are often mid-30s (celsius).
On a hot day, I would reach typically reach for a lightweight mask with good breathability such as the Bloo Mask (I have a review of that mask on this blog). The issue is, I believe that mask still only ships in NZ and Australia. While I haven’t had a chance to try Happy Masks in summer yet, they feel similar to the Bloo Mask in many respects and, as such, I believe they would be a good choice. Happy Masks did leak a bit more than Bloo Masks, but this will differ from person to person – I’ve also been told they are working on resolving this issue.
Valves do add breathability, but I still find a better filter makes more of a difference (this is why I would personally use a nanofibre mask. Perhaps Happy Mask, Metamask, or Bloo Mask. I am sure there are other nanofibre masks out there too). If you do want to try a mask that uses valves, I would try the AirFlex or Urban Air 2.0 as they both have dual-valve designs and should (in theory) perform better in high temperatures.
Unfortunately, I honestly don’t think there is any mask that is comfortable for high temperatures. If there are, I haven’t come across them yet! There are definitely some that are more comfortable than others, however. To answer your question, I personally would reach towards a Bloo Mask but due to the limited availability, Happy Masks are the closest in design. If not Happy Masks, I would look for another mask that uses a nanofibre filter (I know Metamask and Halo Mask do).
I hope this helps! If you have any further questions please feel free to ask.
Ethan
Thanks Ethan for your thoughtful response. You verified what I was thinking. So I will order a Happy Mask and a Metamask. I will try the links on your site for ordering. Thanks again for all your work! Best wishes for health, happiness to you and yours!
So I ordered two happy masks after measuring and they did not fit well at all. I called the company and they would not make things right. They offered me 10%. So I would have ended up paying a little over $100 for 2 masks that I could wear. No thank you! I am very displeased with the CS of happy masks. On the other hand the masks seem like good masks.
I am sorry to hear to hear you had a bad experience. I wanted to point out that there are 2 companies with similar names (one is Happy Masks and the other Happy Mask (not plural). Since the Happy Masks reviewed on the blog are about $25 each, I am wondering if you ended up at the other site since you paid a lot more. I just wanted to comment since the Customer Service that I have encountered at Happy Masks has been nothing short of stellar. I had a hard time finding a mask my son would wear and needed to try one of their masks soon for an upcoming doctor appointment- they expedited my shipping free of charge to make sure it would make it in time. That impressed me so much and we have been loyal customers ever since.
Thank you so much for pointing this out Amy. I had no idea about this other website. I have updated the article to mention that the review is for Happy Masks from Happymasks.com.
Very unhappy with the mask. The nose wire is to thin and flimsy. It is lower than the top edge of mask and I can’t vet a decent seal. I will not wear the mask. There is too much leaking around nose. If a mask does not fit properly, it is useless no matter how many filters it has.
Hello Anna,
I am sorry to hear about the bad experiences that you have had. I wonder if you got the newer version of the mask? I have found that that definitely improved upon the leaks for me.
Same as above. I ordered 6 due to an upcoming trip and based solely on word of mouth recommendations. I am beyond disappointed. The seal is completely inadequate rendering the high efficiency filtration useless. Unlike you, I have found masks manufacturers who were able to address the gaps around the nose, and this mask could do it as well (I’m guessing) if they used stronger nose wire. It’s not rocket science. Otherwise the mask is great, but given that significant gaps means you’re not protected, not protecting others, then again it’s useless. $25 is too much to spend on a useless mask. I’m guessing I’ll have to eat the $160 I just spent, as this company has (from online search) a bad reputation for customer service.
I don’t recommend this mask, and I’d suggest anyone who is promoting is putting their reputation for honesty and reliability at risk. I’d go as far as to say it’s a rip off, and false advertising.
Hello Rita,
I am sorry to hear that you have had such a bad experience with the mask. Thank you for sharing your experiences – I, and other readers, value them greatly. I hope that from the opinions shared we can get a general picture of each mask’s strengths and weaknesses.
However, I stand by what I said. I mentioned multiple times in my article that my writing is based purely on my experiences – I also mentioned that the mask won’t fit everyone as well as it did me. I don’t know what to tell you, other than Happy Masks really do fit me well. I’ve tried many masks (I hope this website can attest to that fact), yet I’ve settled on Happy Masks as my daily masks due to how well they fit me and how light and breathable they are. I don’t know whether or not you meant to target me in your last sentence, but it feels like you did so I wanted to address that.
Again, I really do thank you for sharing your experiences, I hope they are valuable to other readers. In the future, I will try to get more people to test the mask before writing a review (to test the fit across more people). I try very hard to make it clear that parts of these articles (such as the ‘fit’ section) are based purely on my experiences, with my face shape.
Loving your reviews.
I am a high school teacher returning to the classroom in a couple weeks. I’m looking for high efficiency filtration w/o a valve that will also allow me to speak as clearly as possible to my class. I came across this review because you mentioned Happy Masks are easier to talk with. Would this be one you’d recommend in my case? Of course I understand fit, etc. is personal and not something you can speak to.
Many thanks for the thoughtful and thorough reviews.
Hello Dustin,
Happy Masks are a fantastic choice when it comes to voice clarity. There aren’t many masks out there that perform as well as them when it comes to that aspect. I’m only hesitant to recommend them after reading the feedback of other users in the comments (which I recommend that you read if you haven’t already) regarding the fit.
When it comes to voice clarity my usual recommendations would be Happy Masks, Primal Wear Masks (I actually have tried this mask but never published a review), or Styleseal. Styleseal sits closer to the face, but the mask is quite sturdy so I found it to perform well in this respect.
In order to solve the problem of air leaking around my nose, I sewed an additional wire on my happy masks. I used the wide plastic covered wire from a bag of coffee beans, but I suppose there are actual nose wires one could purchase. This has helped me get a great seal.
I am curious to try a newer mask with the longer wire. I wonder if the mask I got for my son in early June is the newer model. It actually slips off his nose frequently. His older one never did that.
i had same issue with my sons, i still haven’t received mine. not sure why they misrepresent the mask to have no leaks, but it is def. a flaw.
My husband and I each have a Happy Mask. We are delighted with them. Neither of us have experienced any problem at all with leaking air around our noses. I wear glasses and they don’t fog up, which means there is no air leaking. 🙂
Prior to the Happy Mask, I had purchased a Castle Grade mask, which is silicone and has disposable filters. It’s a good mask, but it’s uncomfortable (especially in the summertime), looks odd, and I hate fiddling with the filters. Furthermore, it is bulky since it doesn’t fold up.
I can put my Happy Mask in my pocket. I can slip it on in a second or two. It doesn’t leak. I could wear it for hours if I had to. I am going to order some more of them. We got one each just to make sure we liked them before getting more.
Thank you for the review.
the company is awful in cust svc. you don’t get a mask in 3 months and then when you want to cancel they threaten you fees b/c they change your order into a “pre-order” , yeah right. total scam company; should be shut down.
Hello Alex,
At this point, I am very confused about Happy Masks. It seems that a lot of readers have amazing experiences with their customer service while others have terrible experiences. Could you share the URL of the website you purchased from? There seem to be a few with very similar names.
I love the original Happy Masks with the small nose piece below the trim, but hate the new design. After July they changed the malleable nose piece to a rigid and extra long one under the eyes that is very uncomfortable (who wants to feel something hard under your eyes all day), causes rubbing, and leaves gaps any time you move your face/mouth. The original design provided a good seal for me and my kids, but the new design is so stiff it’s impossible to keep a good seal. Additionally, the new mask feels so stiff overall that it’s a constant reminder that you are wearing a mask. The original masks have a soft touch.
Hello,
That’s very interesting. I’ve found the new design to be much better in every way except that it seems to lose more structural rigidity after washes than the original does (this leads to more severe filter collapse). I’m sorry to hear that the new mask is so much worse than the older one, I wonder if perhaps they should sell both alongside each other. However, I guess that would cause production issues.
Thank you for sharing your thoughts!
Hi, what would be your go-to mask recommendation for wearing on long haul flights?
I think most important feature would be breathability (not feeling claustrophobic/hot/mask collapsing)?
Was very disappointed! In the mask !
My grandkids said it was uncomfortable and they had a hard time breathing in it !!
Customer service was rude and very dismissive to me .
Would not recommend buying this mask They also need to hire better customer service people.
All around bad experience and product
We love Happy Masks in our house. My 5 and 7 year old wear them all day at school. The fit wraps nicely around their face shape and stays in place. My kids talk and run with these and I wore one to an intense gym class with no trouble breathing. The shape keeps my kids from chewing on the masks. I find them more comfortable than KN95-style masks, but with the same filtration in lab tests, and washable. Great for plane flights too. It’s true there is a waitlist to get these, but the company tries very hard to get them to customers, and has always shown me good customer service. Fit is personal of course. We only wear Happy Masks!
