Home /Air Quality Monitor Reviews /Sensereo MSC-1 Review – Is Combined…
Sensereo MSC-1 Review – Is Combined Smoke and CO Detection Worth the Upgrade?
Not too long ago, I reviewed the Sensereo MS-1, the first Matter-over-Thread smoke alarm on the market and a device I’d been quietly waiting for someone to build (for quite a while, I must admit). Smoke alarms have lagged behind the rest of the smart home, so any meaningful step forward in that category was going to get my attention. The MS-1 turned out to be a solid product, and you can read the full review for the details.
If I’m honest, though, the device that interested me far more from the start was its sibling. The Sensereo MSC-1 is the same basic platform, but it adds a carbon monoxide sensor alongside the smoke detection. Smoke is the obvious danger most people think about when they hear “fire safety,” but CO is the threat that catches my attention more because it’s silent, invisible, and generally more common as it shows up when fuel-burning appliances misbehave, which they do (sometimes for years before anyone notices).
Sensereo Smart Alarms
The MSC-1 (left) and the MS-1 (right).
That’s not to mention that, for a smart home product specifically, the dual sensing is the more compelling proposition to me. A smoke alarm in a smart home is only useful in extremely rare circumstances, but a combined smoke and CO alarm opens up a wider set of automations – still ones you’ll likely never need, but they’re nice to have. For example, if CO levels start climbing, you can have the house turn on every fan, kill the boiler, open windows, and ping every device in the house before the level gets dangerous. Now, it is worth noting that this isn’t a low-level CO monitor, so it’s probably not particularly sensitive at low levels, but that’s something we’ll come to.
After having and using the MSC-1 for around two months now, so it’s time to share what that experience has been like.
Certification & Performance
Sensereo MSC-1 Certifications
You can see the certifications on the back of the device.
The first thing I wanted to confirm with the MSC-1 was the same thing I confirmed with the MS-1: that this is a proper safety device first and a smart home gadget second. Thankfully, the answer is the same. The MSC-1 holds EN 14604 certification on the smoke side and EN 50291 certification on the carbon monoxide side, both for the European market. This is exactly the combination I expect to see on such a device (at least for the EEA market, but more on that soon).
I covered EN 14604 in detail in the MS-1 review, so I won’t cover the same ground here. The short version is that it’s the European standard for residential smoke alarm devices, published by CEN, and it tests smoke sensitivity using standardised test fires, audible output of at least 85dB at 3 metres, battery life, environmental tolerance, and physical durability. The MSC-1 carries the same smoke-side certification as its smoke-only sibling.
Sensereo MSC-1 Teardown
However, since this device is also a carbon monoxide monitor, I want to dive deeper into the EN 50291 standard as this device also carries that. Published by CENELEC, it covers electrically operated CO detectors intended for continuous use in domestic premises. The most interesting part of this standard is the response thresholds it specifies, because they’re built around how CO harms people rather than around hitting a single trigger level. Here are the thresholds for the alarm to trigger:
  • At 30 ppm, the alarm must not activate before 120 minutes.
  • At 50 ppm, it must not activate for at least 60 minutes but must sound before 90.
  • At 100 ppm, it has between 10 and 40 minutes to alarm.
  • At 300ppm, it must alarm within 3 minutes.
The thresholds tighten as concentration climbs, which matches the fact that CO at 30 ppm over several hours is roughly equivalent in harm to CO at a higher concentration over a few minutes. This is also why a CO alarm doesn’t beep the moment it sees any CO at all. Low concentrations are common in most homes, more so in winter when heating systems run constantly, and a sensor that triggered on every minor reading would potentially be quite annoying. EN 50291 is built to react to exposure risk, not to ambient ppm.
Sensereo MSC-1 Sensor Type
The CO sensor is the large, metal cylinder below the smoke chamber. Unfortunately, there is no label on the sensor.
Please take this with a grain of salt as I haven’t been able to confirm it, but I believe the MSC-1’s CO sensor is from Figaro. Figaro is a Japanese manufacturer that’s been making gas sensors for decades and is widely used in residential CO alarms. From the size of the sensor, I believe this to be the TGS5342, a compact electrochemical sensor with a 10-year design lifespan, a measuring range from 0 to 10,000 ppm, and EN 50291 (and UL2034, but the device itself is not certified) compliance built in. The smoke side of the device uses the same photoelectric chamber as the MS-1, so the same characteristics apply: it’s good for smouldering fires (the more dangerous ones) and less prone to nuisance alarms from cooking and steam than older alarms.
One feature the MSC-1 adds over the MS-1 is a built-in LCD that displays the current CO reading in parts per million. This can be useful, but with a caveat. Figaro’s residential CO sensors (the TGS5342 included) are well regarded for alarm-level detection, where they can reliably distinguish a dangerous CO concentration from background noise but they’re less precise at the low end of the scale, where accurate ambient ppm readings would matter for general air quality monitoring. So, if the display shows something like 5 or 10 ppm, you should only treat this as a rough figure as the baseline offset is listed as <±10ppm. Importantly, the sensor performs well across different temperatures within its operating conditions and doesn’t have major cross sensitivities to any tested gasses.
Figaro Cross Sensitivities
Far from scientific, but to confirm the device actually works, I ran the same kinds of tests I did with the MS-1 to see how the MSC-1 behaves in practice. While cooking (with a few items intentionally burnt), my indoor air quality monitor climbed to around 1,500 μg/m³ PM2.5, a reading far into the hazardous range on any air quality scale, and the MSC-1 didn’t trigger. In this case that’s exactly what I wanted, because cooking shouldn’t set off your smoke alarm – even if you burn something very badly. For the actual smoke test, I put the device in an airtight container, burned a small amount of paper inside it, and watched what happened. The MSC-1 triggered after about one minute, and the CO concentration on the LCD climbed to over 80 ppm. Unfortunately, I only learnt about the different alarm patterns for CO and smoke after the fact, so I am unsure which alarm (or both) triggered. However, it did its job of alerting me about a dangerous situation.
Unfortunately, for the US market, the same situation applies as with the MS-1. Sensereo has confirmed they’re working on UL certifications (UL 217 for smoke and UL 2034 for CO) but the MSC-1 doesn’t currently carry those. If you’re in the US, this isn’t the device for you yet, and the same warning applies: don’t run an alarm in a country where it isn’t certified. While the device will still function normally, there are other factors to consider. For example, you might not be eligible for insurance coverage if your alarms don’t meet local regulations. If you really want a smart alarm, you could consider running this alongside a ‘dumb’ alarm that carries a local certification.
Finally, as for lifespan, the MSC-1 is rated for seven years from installation, after which it needs replacing. That’s slightly shorter than the 10-year design lifespan of the Figaro CO sensor itself, but Sensereo (like most EU manufacturers) tends to land on the conservative end of the typical lifespan window, and the photoelectric smoke chamber is the limiting factor. The MSC-1 has an end-of-life warning built in. And just like the MS-1, the MSC-1 keeps working as a basic “dumb” smoke and CO alarm even if your network goes down. However, one key difference here is that everything is run off a single, replaceable battery. In the MS-1, there was one battery dedicated to Matter connectivity, and one to the alarm itself. I assume this difference is due to size constraints inside the device.
Purchase the MSC-1
Functionality & Placement
Sensereo MSC-1 Screen
Out of the box, the MSC-1 looks like a standard residential smoke and CO alarm. It measures 115 x 115 x 42mm and weighs 190g, so it’s slightly larger and heavier than the smoke-only MS-1 (which comes in at 110 x 110 x 41.6mm and 165g). However, for a device that sits on your ceiling, this size difference is negligible, especially considering that the extra space and weight cover the CO sensor, the LCD display, and the ring light around the outer edge. Once mounted on a ceiling, the alarm disappears into the background the way you want any smoke alarm to disappear. To be honest, I usually forget mine is even there. On that note, If you didn’t know it was a smart device, you’d assume it was a standard alarm.
In saying that, there are a few design touches that set the MSC-1 apart. The most obvious being the LCD screen on the front that shows the current CO concentration in parts per million. I love the idea of this in principle, but the execution depends on where you mount it (and the low concentration caveats I mentioned earlier). In a house with normal ceilings, the screen will be readable to most people when you walk underneath. In our house, the living room ceiling tops out at around 5 metres high, so I’d need to be a giraffe to read the screen properly. If I squint I can barely make out the values, but I prefer to just check them on Home Assistant if needed.
That brings me to placement, which is really not much more different for a combined smoke and CO alarm than for a smoke-only one. Smoke alarms should always be ceiling-mounted because smoke rises. CO is roughly the same density as air, so where you put the CO sensor matters less. The EPA recommends mounting CO alarms about 5 feet above the floor on a wall (roughly eye level), but ceiling mounting is also acceptable since CO disperses evenly through a room. Sensereo’s own guidance is to ceiling-mount the MSC-1 the same way you’d mount the MS-1 as placement for smoke is more important in this case. Refer to the manual for the full placement guidance, including the same caveats around damp areas, cooking spaces, vents, and extreme temperatures that applied to the MS-1.
Sensereo MSC-1 LED Bar
The second design touch I appreciate is the ring of LED around the outer edge of the device. By default this will flash green every 60 seconds to indicate the device is on and functioning. When smoke is detected, it flashes red three times in quick succession with three long beeps every 1.5 seconds. When CO is detected, it flashes red four times with four long beeps every 5 seconds. While you probably won’t remember these combinations in the moment, you’ll at least know you need to act. The ring light is bright enough to be visible across a room (especially in the dark). Behind the LED bar sits the venting that allows air to pass through the device for measurement.
On the back of the device you’ll find an on/off switch (for the communication module), the Matter QR code for pairing, the regulatory print, the alarm thresholds (printed so you can check them at a glance), and the replaceable battery compartment. The MSC-1 runs on a single user-replaceable CR123A that powers everything, both the safety functionality and the Matter radio. Sensereo expects the battery to last around three years between replacements, and you’ll get a low-battery notification through your smart home platform when it’s getting close.
Sensereo MSC-1 Backplate
As mentioned in the Performance & Certification section, the single-battery design is a significant change from the MS-1, which used a dual setup (a sealed cell for the core smoke detection plus a replaceable CR123A for the connectivity side). Sensereo hasn’t published a clear reason for the design difference, but the most plausible explanations are either space constraints (the CO sensor is quite large!) or the extra power consumption of adding the CO sensor meaning a user-replaceable battery is needed. Whatever the reason, the practical takeaway is the same: when the MSC-1 says replace the battery, replace the battery.
Sensereo MSC-1 Mounting Bracket
The MSC-1 ships with a mounting bracket and screws, and the bracket uses the same twist-to-lock mechanism as the MS-1. Pop the alarm onto the bracket, rotate to lock, and rotate the other way when you want it back down. The alarm itself is rated at 85dB at 3 metres, the EN 14604 minimum, and that holds true for both the smoke and CO alarm patterns. There’s a large button on the top for self-testing, and Sensereo recommends running that test monthly to confirm the alarm is doing its job.
Hush mode is here too, and it allows you to disable the alarm if you know you’re not in danger. For example, if the alarm goes off in a situation where you know there’s no real fire risk (a piece of toast gone VERY wrong…), press the Hush button to silence the buzzer until the alarm ends. While Hush is active, the ring LED flashes every 45 seconds to remind you the alarm is still on standby. Hush is the right call for a false smoke alarm, but if the MSC-1 is alarming because of CO, the right response is to ventilate the space and find the source rather than silence the alarm. It’s also worth mentioning that you can’t hush the device if the CO concentration exceeds 300 ppm.
Purchase the MSC-1
MSC-1 Home Assistant
Like the MS-1, the MSC-1 connects to your smart home over Matter, running on Thread. I won’t repeat the full Matter primer here since I covered it in the MS-1 review, but the short version is that Matter is a cross-platform standard that lets devices from different brands work together, and Thread is the low-power mesh network the MSC-1 uses to talk to your home. In other words, this device does not use WiFi and you’ll need a Thread border router somewhere on your network for the MSC-1 to pair (most recent Apple TVs, Echo Show and Echo Dot Max devices, some Google Nest devices, and some other devices qualify). If you don’t already have one, you’ll need to add one before you can use any of the connectivity features of the MSC-1.
The big advantage of Matter is that the MSC-1 isn’t tied to a single ecosystem. You can expose it to Apple Home, Alexa, Google Home, Home Assistant, and SmartThings at the same time. In my setup, the MSC-1 lives on Alexa and Home Assistant simultaneously, with my Apple TV 4K acting as the Thread border router on the network. Both platforms see the same device, but they show you different amounts of detail. Alexa surfaces only three basic states (normal, warning, severe), whereas Home Assistant exposes much more, including the current CO reading in ppm, the smoke detection state, battery voltage, end-of-life timer, and a remote alarm test. If you want full visibility into what the MSC-1 is doing, HA is the place to do it and Alexa felt quite underwhelming (as it often does).
Home Assistant Dashboard
I love the concept of Matter, but in practice I’ve found it temperamental. This isn’t a problem with the MSC-1 specifically. It’s a problem I keep running into across Matter devices in general. Pairing sometimes takes more than one attempt (and sometimes more than 10). Devices occasionally drop off a controller and need to be re-added and border router behaviour varies by manufacturer. The MSC-1 has been better-behaved than most Matter devices I’ve used, but if you’re new to Matter, set your expectations accordingly as it’s a young standard and there are still quite a few rough edges. None of this affects the MSC-1’s core safety functionality, which runs independently of the network, but it’s worth flagging for anyone expecting plug-and-play perfection.
MSC-1 HA
The smart side also doesn’t deliver value on its own. The MSC-1 will quietly sit there reporting “normal” most of the time, and if all you’ve done is add it to your smart home app, you’ve added a notification source and not much more. The real benefit of a smart smoke and CO alarm comes from building it into automations, and that needs you to have other smart home equipment in place to act on what the MSC-1 detects.
This is where the MSC-1 starts to pull ahead of the MS-1 in usefulness, because CO opens up some automation possibilities that a smoke-only alarm doesn’t. Some of the more useful ones:
  • HVAC and gas appliance shutoff when CO is detected. CO is almost always coming from a fuel-burning appliance (a boiler, a furnace, a water heater, a stove with a leaky line), so if the MSC-1 sees CO and your boiler is connected to a smart switch or relay, you can cut power to it automatically.
  • Ventilation. If CO levels start climbing, you can open smart vents or trigger smart blinds in a sunroom to crack open. Even running a bathroom extractor fan at full speed helps move air through the house. Anything that increases air exchange while you work out where the CO is coming from.
  • Remote notifications and remote checking. Same as the MS-1, but with a CO reading attached. If I’m out and get a CO notification, I can open Home Assistant and see the actual ppm value and take action accordingly.
  • All alarms sounding together. Same logic as the MS-1. If you have multiple alarms (or speakers) in the house, you can build an automation so any one of them triggering makes the rest sound.
  • Lights to full brightness. CO can cause confusion and disorientation as it builds up, and a brightly lit house makes it easier to get out.
Of course, there are likely many more automations that I haven’t even considered yet!
Purchase the MSC-1
Pricing & Alternatives
MSC-1 Sensereo Price
The MSC-1 sits at around $70 USD, with similar pricing in euros and pounds. That’s a $20 step up from the smoke-only MS-1, and meaningfully more than a basic combined smoke and CO alarm. A no-frills EN 14604 + EN 50291 certified combo alarm in the UK runs anywhere from £20 to £40 depending on the brand, build, and whether you want extras like a digital display or radio interlink. So you’re paying roughly two to three times more for the MSC-1 over a basic certified combo, and the math works the same way it did with the MS-1: if you can put the Matter integration to work, the premium is reasonable. If you can’t, a basic alarm covers the safety side for much less.
First, let’s compare the MSC-1 to its sibling since most readers landing here will already have picked Sensereo for the Matter angle and are deciding between the smoke-only MS-1 and the combined MSC-1. Personally, I’d pay the extra $20 for the MSC-1 in most rooms. CO detection is extra peace of mind over smoke detection, and rolling both into a single device covers ground that would otherwise need two separate alarms (or, more likely, just no CO coverage at all, which is how most homes end up). The MSC-1 is the more well-rounded safety device, and for the relative price difference, I think it’s worth having at least one in the house.
The bigger question, the one the MS-1 review also raised, is whether you actually need a smart alarm in the first place. That depends on how smart your home already is and how much you value remote notifications when you’re not home. If your home has automations wired up that can act on alarm events (HVAC shutoff, ventilation, alarm propagation across multiple devices), the smart side earns its keep. If you mostly want to know about events while you’re out, the push notifications alone are a decent reason. If neither of these is valuable to you, a basic certified combo alarm will do the safety job for a fraction of the price.
When it comes to the competition, Matter-over-Thread combo alarms, the MSC-1 is still on its own. Aqara and Meross both have Matter smoke alarms that work via a Matter Bridge or vendor hub, but neither sells a native Matter-over-Thread combined smoke and CO unit at the time of writing. As far as I can tell from the current market, the MSC-1 is the only product in its category, which is an unusual position and leaves US customers in an awkward spot.
If you broaden the lens past Matter, the US market has two obvious choices: the First Alert SC5 (a combined smoke and CO alarm certified to UL 217 and UL 2034, with Google Home integration) and the Kidde smart smoke and CO range (with Ring integration and a hardwired option). Both are reasonable picks for US homes and cost broadly in the same range as the MSC-1, though neither has Matter.
Purchase the MSC-1
Sensereo MSC-1 Box Contents
Generally speaking, the MSC-1 is just a smoke and CO alarm, and these are essential safety equipment in any home. Most fire safety guidance suggests you should have several smoke alarms around the house (one per bedroom, one per living area, one per hallway) and at least one CO alarm near every fuel-burning appliance. By that standard, devices like the MSC-1 belong in every European home that meets the certification scope, regardless of whether you care about the smart side.
Cost is where it gets complicated. The MSC-1 costs significantly more than a basic dumb combined alarm. A no-frills EN 14604 + EN 50291 certified combo can be had for under £30, and replacing the MSC-1 every seven years adds up over time. If safety is the only thing you care about and you’re not going to use the smart features, a basic alarm does the same fire and CO detection job for a fraction of the price.
However, if you’ve already built out the smart home infrastructure to act on what the MSC-1 reports, this is a strong choice. Right now, it’s also the only choice if you specifically want a Matter-over-Thread combined smoke and CO alarm. The HVAC shutoff automations and remote notifications I mentioned earlier are useful in the rare event that something goes wrong, and combined smoke and CO coverage in a single device is a cleaner setup than running two separate alarms.
There’s a harder question underneath all this: whether you actually need a smart alarm in the first place. The MSC-1 is a fine smart alarm, and it’s the only Matter-over-Thread option for combined detection on the market today. Whether any of that justifies the extra spend over a basic certified combo is something only you can answer. It comes down to how much value you place on remote alerts and the ability to automate around what the alarm reports. For me, the answer was yes. For most homes, it’s a genuine “depends.”
  • The only native Matter-over-Thread combined smoke and CO alarm on the market
  • EN 14604 and EN 50291 certified for both smoke and CO detection
  • Works across Apple Home, Alexa, Google Home, Home Assistant, and SmartThings
  • Built-in LCD shows live CO readings in ppm
  • Distinct alarm patterns and ring LED behaviour for smoke vs CO
  • Hush mode silences false smoke alarms for 8-10 minutes
  • Detailed status visibility through Home Assistant
  • Not certified for the US market yet (no UL 217 or UL 2034)
  • LCD is hard to read if mounted on a high ceiling
  • CO reading is approximate at low ppm values
  • Roughly 2-3x the price of a basic EN 14604 + EN 50291 combo alarm
  • Needs a Thread border router on your network
  • 7-year lifespan, shorter than NFPA’s 10-year recommendation
Purchase the MSC-1
Sensereo MSC-1 FAQ
What’s the difference between the MSC-1 and the MS-1?
The MS-1 is a smoke-only alarm. The MSC-1 adds an electrochemical carbon monoxide sensor alongside the same photoelectric smoke chamber, plus an LCD on the front that shows the current CO concentration in ppm. The MSC-1 costs about $20 more than the MS-1 and runs on a single replaceable CR123A battery, where the MS-1 uses a dual-battery setup with one sealed cell for safety and one replaceable cell for connectivity. Both devices are EN 14604 certified for smoke detection, but only the MSC-1 also carries EN 50291 certification for CO.
Does the Sensereo MSC-1 work in the US?
The MSC-1 is currently certified to EN 14604 and EN 50291 for the EU and UK only. It doesn’t yet carry UL 217 or UL 2034 certification, which are the US standards for smoke and CO alarms respectively. Sensereo has confirmed they’re working on UL certification for a future US variant, but for now this is a European product. US buyers should look at the First Alert SC5 or another UL 217 and UL 2034 certified combo alarm instead.
Can I trust the CO ppm reading on the display?
At alarm-relevant concentrations, yes. The MSC-1’s CO sensor is a Figaro electrochemical sensor designed to reliably flag dangerous CO levels per the EN 50291 standard. At low concentrations though (say, single-digit ppm), treat the displayed number as approximate rather than a calibrated measurement. The sensor is built for residential safety alerts, not for high-precision ambient air quality monitoring.
Where should I install the MSC-1, on the ceiling or on a wall?
Sensereo recommends ceiling mounting, the same as the MS-1, at least 0.5 metres from any wall. Smoke alarms work best on the ceiling because smoke rises. CO is roughly the same density as air, so ceiling mounting is also acceptable for CO detection, though the EPA’s general guidance for CO-only alarms is about 5 feet above the floor on a wall (eye level). Avoid kitchens, bathrooms, garages, areas near vents or fans, and locations where the temperature climbs above 50°C or drops below 0°C. See the manual for the full placement guidance before you mount it.
Will the MSC-1 still work if my Wi-Fi or smart home goes down?
Yes. The MSC-1 will keep detecting smoke and CO and sound the alarm even if your network drops out. The smart features (push notifications, app status, automations) go quiet until things come back online, but the safety functionality runs independently. The one caveat is that the MSC-1 uses a single replaceable CR123A battery for everything, so if you’ve ignored a low-battery warning long enough for the cell to die, the whole device goes offline. Replace the battery when the low-battery notification arrives.
